Calibration adapter
Hi.
I want to calibrate my Dynamixel servo XM430.
I have watched the video on how to calibrate, in the video they use a calibration adapter.
Where can I buy one?
BR
Peter Svensson
Hi @peter.svensson, thanks for your question!
The calibration adapter for DYNAMIXELs is generally included with the set of replacement gears that ROBOTIS offers for that model. Replacement gears for DYNAMIXELs can be found here on the ROBOTIS.US online shop, and there should be separate gear sets available for XM/XH430-W210-T/R and XM/XH430-W350-T/R. Be sure to select the set with the correct gear ratio for use with your servo :slight_smile:
Let me know if you have any other questions!
Hi.
Is there any company selling the replacement gear kit outside US?
I live in Sweden (northen Europe).
I have tried to buy the 2700-903-0252-000 kit from https://www.robotis.us/ and Digikey.se.
Both say that they dont sell the replacement gear kit outside the US.
BR
Peter
Hello @peter.svensson, thanks for your question. You should be able to make purchases for delivery to Northern Europe from our International Online Shop linked here.
Let me know if this helps or whether you have any other questions we can assist with!
Thank you.
I’m using Google Chrome and I get a warning about URL not being safe.
NET::ERR_CERT_COMMON_NAME_INVALID
BR
Peter
Hello @peter, thanks for sharing the update. It’s interesting to see that warning since I did not receive it yesterday. @Tech_Support , can you look into the reason for the warning?
@Andrew
You were trying to connect via https protocol which the ROBOTIS are not hosting through currently. Could you tell me where did you copy that address?
@peter.svensson
Please check out the link http://en.robotis.com/shop_en/list.php?ca_id=302080 here.
Thank you,
Gear | ROBOTIS ](Gear | ROBOTIS) works fin.
Thank you
/Peter
@peter.svensson
No worry
