Hello All,
I am using Dynamixel MX Series 64 AR Servos and using Open CM Exp+ Open CM 9.04 hardware. Can anyone provide me a sample code to run the servos? Currently, I am using the following code
Dynamixel : MX-series with Protocol 2.0(MX-28 2.0, MX-64 2.0, MX-106 2.0)
Controller : OpenCM9.04C + OpenCM 485 EXP
Power Source : SMPS 12V 5A
MX-Series are connected to Dynamixel BUS on OpenCM 485 EXP board
This example will test only one Dynamixel at a time.
*/#include <DynamixelSDK.h>
// Control table address (MX-series with Protocol 2.0)
#define ADDR_MX_TORQUE_ENABLE 64 // Control table address is different in Dynamixel model
#define ADDR_MX_GOAL_POSITION 116
#define ADDR_MX_PRESENT_POSITION 132// Protocol version
#define PROTOCOL_VERSION 2.0 // See which protocol version is used in the Dynamixel// Default setting
#define DXL_ID 1 // Dynamixel ID: 1
#define BAUDRATE 57600
#define DEVICENAME “3” //DEVICENAME “1” → Serial1(OpenCM9.04 DXL TTL Ports)
//DEVICENAME “2” → Serial2
//DEVICENAME “3” → Serial3(OpenCM 485 EXP)
#define TORQUE_ENABLE 1 // Value for enabling the torque
#define TORQUE_DISABLE 0 // Value for disabling the torque
#define DXL_MINIMUM_POSITION_VALUE 0 // Dynamixel will rotate between this value
#define DXL_MAXIMUM_POSITION_VALUE 4000 // and this value (note that the Dynamixel would not move when the position value is out of movable range. Check e-manual about the range of the Dynamixel you use.)
#define DXL_MOVING_STATUS_THRESHOLD 20 // Dynamixel moving status threshold#define ESC_ASCII_VALUE 0x1b
Serial.begin(115200);
while(!Serial);Serial.println(“Start…”);
// Initialize PortHandler instance
// Set the port path
// Get methods and members of PortHandlerLinux or PortHandlerWindows
dynamixel::PortHandler *portHandler = dynamixel::PortHandler::getPortHandler(DEVICENAME);// Initialize PacketHandler instance
// Set the protocol version
// Get methods and members of Protocol1PacketHandler or Protocol2PacketHandler
dynamixel::PacketHandler *packetHandler = dynamixel::PacketHandler::getPacketHandler(PROTOCOL_VERSION);int index = 0;
int dxl_comm_result = COMM_TX_FAIL; // Communication result
int dxl_goal_position[2] = {DXL_MINIMUM_POSITION_VALUE, DXL_MAXIMUM_POSITION_VALUE}; // Goal positionuint8_t dxl_error = 0; // Dynamixel error
int32_t dxl_present_position = 0; // Present position// Open port
if (portHandler->openPort())
Serial.print(“Succeeded to open the port!\n”);
else
Serial.print(“Failed to open the port!\n”);
Serial.print(“Press any key to terminate…\n”);
return;
}// Set port baudrate
if (portHandler->setBaudRate(BAUDRATE))
Serial.print(“Succeeded to change the baudrate!\n”);
else
Serial.print(“Failed to change the baudrate!\n”);
return;
}// Enable Dynamixel Torque
dxl_comm_result = packetHandler->write1ByteTxRx(portHandler, DXL_ID, ADDR_MX_TORQUE_ENABLE, TORQUE_ENABLE, &dxl_error);
if (dxl_comm_result != COMM_SUCCESS)
packetHandler->getTxRxResult(dxl_comm_result);
else if (dxl_error != 0)
packetHandler->getRxPacketError(dxl_error);
else
Serial.print(“Dynamixel has been successfully connected \n”);
}while(1)
Serial.print(“Press any key to continue! (or press q to quit!)\n”);while(Serial.available()==0); int ch; ch = Serial.read(); if (ch == 'q') break; // Write goal position dxl_comm_result = packetHandler->write4ByteTxRx(portHandler, DXL_ID, ADDR_MX_GOAL_POSITION, dxl_goal_position[index], &dxl_error); if (dxl_comm_result != COMM_SUCCESS) { packetHandler->getTxRxResult(dxl_comm_result); } else if (dxl_error != 0) { packetHandler->getRxPacketError(dxl_error); } do { // Read present position dxl_comm_result = packetHandler->read4ByteTxRx(portHandler, DXL_ID, ADDR_MX_PRESENT_POSITION, (uint32_t*)&dxl_present_position, &dxl_error); if (dxl_comm_result != COMM_SUCCESS) { packetHandler->getTxRxResult(dxl_comm_result); } else if (dxl_error != 0) { packetHandler->getRxPacketError(dxl_error); } Serial.print("[ID:"); Serial.print(DXL_ID); Serial.print(" GoalPos:"); Serial.print(dxl_goal_position[index]); Serial.print(" PresPos:"); Serial.print(dxl_present_position); Serial.println(" "); }while((abs(dxl_goal_position[index] - dxl_present_position) > DXL_MOVING_STATUS_THRESHOLD)); // Change goal position if (index == 0) { index = 1; } else { index = 0; }
// Disable Dynamixel Torque
dxl_comm_result = packetHandler->write1ByteTxRx(portHandler, DXL_ID, ADDR_MX_TORQUE_ENABLE, TORQUE_DISABLE, &dxl_error);
}// Close port
portHandler->closePort();}
// put your main code here, to run repeatedly:}
I want to see a sample main code to run servos.
