Hi, thank you so much for the quick reply. Here is the code:
- Dynamixel : AX-series with Protocol 1.0
- Controller : OpenCM9.04C + OpenCM 485 EXP
- Power Source : SMPS 12V 5A
- AX-Series are connected to Dynamixel BUS on OpenCM 485 EXP board or DXL TTL connectors on OpenCM9.04
- OpenCM 485 EXP
- This example will test only one Dynamixel at a time.
#include <DynamixelSDK.h>
// AX-series Control table address
#define ADDR_AX_TORQUE_ENABLE 24 // Control table address is different in Dynamixel model
#define ADDR_AX_GOAL_POSITION 30
#define ADDR_AX_PRESENT_POSITION 36
// Protocol version
#define PROTOCOL_VERSION 1.0 // See which protocol version is used in the Dynamixel
// Default setting
#define DXL_ID 1 // Dynamixel ID: 1
#define BAUDRATE 1000000
#define DEVICENAME “3” //DEVICENAME “1” → Serial1(OpenCM9.04 DXL TTL Ports)
//DEVICENAME “2” → Serial2
//DEVICENAME “3” → Serial3(OpenCM 485 EXP)
#define TORQUE_ENABLE 1 // Value for enabling the torque
#define TORQUE_DISABLE 0 // Value for disabling the torque
#define DXL_MINIMUM_POSITION_VALUE 100 // Dynamixel will rotate between this value
#define DXL_MAXIMUM_POSITION_VALUE 1000 // and this value (note that the Dynamixel would not move when the position value is out of movable range. Check e-manual about the range of the Dynamixel you use.)
#define DXL_MOVING_STATUS_THRESHOLD 20 // Dynamixel moving status threshold
#define ESC_ASCII_VALUE 0x1b
Serial.begin(115200);
while(!Serial);
Serial.println(“Start…”);
// Initialize PortHandler instance
// Set the port path
// Get methods and members of PortHandlerLinux or PortHandlerWindows
dynamixel::PortHandler *portHandler = dynamixel::PortHandler::getPortHandler(DEVICENAME);
// Initialize PacketHandler instance
// Set the protocol version
// Get methods and members of Protocol1PacketHandler or Protocol2PacketHandler
dynamixel::PacketHandler *packetHandler = dynamixel::PacketHandler::getPacketHandler(PROTOCOL_VERSION);
int index = 0;
int dxl_comm_result = COMM_TX_FAIL; // Communication result
int dxl_goal_position[2] = {DXL_MINIMUM_POSITION_VALUE, DXL_MAXIMUM_POSITION_VALUE}; // Goal position
uint8_t dxl_error = 0; // Dynamixel error
int16_t dxl_present_position = 0; // Present position
// Open port
if (portHandler->openPort())
Serial.print(“Succeeded to open the port!\n”);
else
Serial.print(“Failed to open the port!\n”);
Serial.print(“Press any key to terminate…\n”);
return;
// Set port baudrate
if (portHandler->setBaudRate(BAUDRATE))
Serial.print(“Succeeded to change the baudrate!\n”);
else
Serial.print(“Failed to change the baudrate!\n”);
return;
// Enable Dynamixel Torque
dxl_comm_result = packetHandler->write1ByteTxRx(portHandler, DXL_ID, ADDR_AX_TORQUE_ENABLE, TORQUE_ENABLE, &dxl_error);
if (dxl_comm_result != COMM_SUCCESS)
packetHandler->getTxRxResult(dxl_comm_result);
else if (dxl_error != 0)
packetHandler->getRxPacketError(dxl_error);
else
Serial.print(“Dynamixel has been successfully connected \n”);
while(1)
Serial.print(“Press any key to continue! (or press q to quit!)\n”);
while(Serial.available()==0);
int ch;
ch = Serial.read();
if( ch == 'q' )
break;
// Write goal position
dxl_comm_result = packetHandler->write2ByteTxRx(portHandler, DXL_ID, ADDR_AX_GOAL_POSITION, dxl_goal_position[index], &dxl_error);
do
// Read present position
dxl_comm_result = packetHandler->read2ByteTxRx(portHandler, DXL_ID, ADDR_AX_PRESENT_POSITION, (uint16_t*)&dxl_present_position, &dxl_error);
Serial.print("[ID:"); Serial.print(DXL_ID);
Serial.print(" GoalPos:"); Serial.print(dxl_goal_position[index]);
Serial.print(" PresPos:"); Serial.print(dxl_present_position);
Serial.println(" ");
}while((abs(dxl_goal_position[index] - dxl_present_position) > DXL_MOVING_STATUS_THRESHOLD));
// Change goal position
if (index == 0)
index = 1;
else
index = 0;
// Disable Dynamixel Torque
dxl_comm_result = packetHandler->write1ByteTxRx(portHandler, DXL_ID, ADDR_AX_TORQUE_ENABLE, TORQUE_DISABLE, &dxl_error);
// Close port
portHandler->closePort();
I am using DynamixelSDK on Arduino and the example for Protocol 1.0. I’m able to run the blinker test just fine and I also see the light when the Dynamixels get power, I just need to move them. Am I using the wrong ports to write to the Dynamixels?
