I once again have another error which I am currently struggling to solve. I have successfully uploaded the compiled code onto the turtlebot. I am now encountering an error which outputs “Tried to publish before configured, topic id 131”. This error is appearing inside of the terminal window in which I am launching the roslaunch command.
If you have any suggestions as to how I could solve this error, it would be greatly appreciated. Your help has not gone unappreciated!
Once again, I will be posting the error message(s) below.
SUMMARY
PARAMETERS
- /rosdistro: noetic
- /rosversion: 1.15.11
- /turtlebot3_core/baud: 115200
- /turtlebot3_core/port: /dev/ttyACM0
- /turtlebot3_core/tf_prefix:
- /turtlebot3_lds/frame_id: base_scan
NODES
turtlebot3_core (rosserial_python/serial_node.py)
turtlebot3_diagnostics (turtlebot3_bringup/turtlebot3_diagnostics)
turtlebot3_lds (ld08_driver/ld08_driver)
ROS_MASTER_URI=http://192.168.0.196:11311
process[turtlebot3_core-1]: started with pid [2244]
process[turtlebot3_lds-2]: started with pid [2245]
process[turtlebot3_diagnostics-3]: started with pid [2246]
/dev/ttyACM0 OpenCR Virtual ComPort in FS Mode
/dev/ttyUSB0 CP2102 USB to UART Bridge Controller
FOUND LiDAR_LD08 @port :/dev/ttyUSB0
[INFO] [1683900507.010733]: ROS Serial Python Node
[INFO] [1683900507.050099]: Connecting to /dev/ttyACM0 at 115200 baud
[INFO] [1683900509.170383]: Requesting topics…
[INFO] [1683900509.360679]: Note: publish buffer size is 1024 bytes
[INFO] [1683900509.368741]: Setup publisher on sensor_state [turtlebot3_msgs/SensorState]
[INFO] [1683900509.386934]: Setup publisher on firmware_version [turtlebot3_msgs/VersionInfo]
[INFO] [1683900509.769946]: Setup publisher on imu [sensor_msgs/Imu]
[INFO] [1683900509.788884]: Setup publisher on cmd_vel_rc100 [geometry_msgs/Twist]
[INFO] [1683900509.928308]: Setup publisher on odom [nav_msgs/Odometry]
[INFO] [1683900509.947655]: Setup publisher on joint_states [sensor_msgs/JointState]
[ERROR] [1683900509.959059]: Creation of publisher failed: Checksum does not match: 4ddae7f048e32fda22cac764685e3974,476f837fa6771f6e16e3bf4ef96f8770
[INFO] [1683900509.976326]: Setup publisher on magnetic_field [sensor_msgs/MagneticField]
[INFO] [1683900509.994108]: Setup publisher on illuminance [sensor_msgs/Illuminance]
[INFO] [1683900510.575230]: Setup publisher on /tf [tf/tfMessage]
[INFO] [1683900510.600442]: Note: subscribe buffer size is 1024 bytes
[INFO] [1683900510.608574]: Setup subscriber on cmd_vel [geometry_msgs/Twist]
[INFO] [1683900510.632532]: Setup subscriber on sound [turtlebot3_msgs/Sound]
[INFO] [1683900510.657214]: Setup subscriber on motor_power [std_msgs/Bool]
[INFO] [1683900510.799895]: Setup subscriber on reset [std_msgs/Empty]
[INFO] [1683900510.827401]: Setup subscriber on illuminance_topic [sensor_msgs/Illuminance]
[INFO] [1683900512.516045]: Setup TF on Odometry [odom]
[INFO] [1683900512.527190]: Setup TF on IMU [imu_link]
[INFO] [1683900512.537803]: Setup TF on MagneticField [mag_link]
[INFO] [1683900512.548656]: Setup TF on JointState [base_link]
[ERROR] [1683900512.622545]: Tried to publish before configured, topic id 131
[INFO] [1683900512.630870]: Requesting topics…
[INFO] [1683900515.182262]: Calibration End
[INFO] [1683900515.281515]: Setup publisher on sensor_state [turtlebot3_msgs/SensorState]
[INFO] [1683900515.293434]: Setup publisher on firmware_version [turtlebot3_msgs/VersionInfo]
[INFO] [1683900515.304815]: Setup publisher on imu [sensor_msgs/Imu]
[INFO] [1683900515.315969]: Setup publisher on cmd_vel_rc100 [geometry_msgs/Twist]
[INFO] [1683900515.327994]: Setup publisher on odom [nav_msgs/Odometry]
[INFO] [1683900515.339780]: Setup publisher on joint_states [sensor_msgs/JointState]
[ERROR] [1683900515.351288]: Creation of publisher failed: Checksum does not match: 4ddae7f048e32fda22cac764685e3974,476f837fa6771f6e16e3bf4ef96f8770
[INFO] [1683900515.362460]: Setup publisher on magnetic_field [sensor_msgs/MagneticField]
[INFO] [1683900515.373108]: Setup publisher on illuminance [sensor_msgs/Illuminance]
[INFO] [1683900515.388594]: Setup publisher on /tf [tf/tfMessage]
[ERROR] [1683900515.414794]: Tried to publish before configured, topic id 131
[INFO] [1683900515.423299]: Requesting topics…
[ERROR] [1683900515.500528]: Tried to publish before configured, topic id 131
[INFO] [1683900515.508704]: Requesting topics…
[ERROR] [1683900515.606293]: Tried to publish before configured, topic id 131
[INFO] [1683900515.614474]: Requesting topics…
[ERROR] [1683900515.712783]: Tried to publish before configured, topic id 131
[INFO] [1683900515.721219]: Requesting topics…
[ERROR] [1683900515.817456]: Tried to publish before configured, topic id 131
[INFO] [1683900515.826375]: Requesting topics…
[ERROR] [1683900515.924927]: Tried to publish before configured, topic id 131
[INFO] [1683900515.933353]: Requesting topics…
[ERROR] [1683900516.029583]: Tried to publish before configured, topic id 131
[INFO] [1683900516.038178]: Requesting topics…
[ERROR] [1683900516.136255]: Tried to publish before configured, topic id 131
[INFO] [1683900516.144432]: Requesting topics…
[ERROR] [1683900516.242981]: Tried to publish before configured, topic id 131
[INFO] [1683900516.255962]: Requesting topics…
[ERROR] [1683900516.349010]: Tried to publish before configured, topic id 131
[INFO] [1683900516.359220]: Requesting topics…
[ERROR] [1683900516.454101]: Tried to publish before configured, topic id 131
[INFO] [1683900516.462500]: Requesting topics…
[ERROR] [1683900516.560683]: Tried to publish before configured, topic id 131
[INFO] [1683900516.569119]: Requesting topics…
[ERROR] [1683900516.666463]: Tried to publish before configured, topic id 131
[INFO] [1683900516.675929]: Requesting topics…
[ERROR] [1683900516.772262]: Tried to publish before configured, topic id 131
[INFO] [1683900516.780741]: Requesting topics…
[ERROR] [1683900516.878323]: Tried to publish before configured, topic id 131
[INFO] [1683900516.886464]: Requesting topics…
[ERROR] [1683900516.983977]: Tried to publish before configured, topic id 131
[INFO] [1683900516.992582]: Requesting topics…
[ERROR] [1683900517.090626]: Tried to publish before configured, topic id 131
[INFO] [1683900517.099993]: Requesting topics…
[ERROR] [1683900517.195957]: Tried to publish before configured, topic id 131
[INFO] [1683900517.204731]: Requesting topics…
[ERROR] [1683900517.302357]: Tried to publish before configured, topic id 131
[INFO] [1683900517.311394]: Requesting topics…
[ERROR] [1683900517.409309]: Tried to publish before configured, topic id 131
[INFO] [1683900517.417980]: Requesting topics…
[ERROR] [1683900517.514630]: Tried to publish before configured, topic id 131
[INFO] [1683900517.522785]: Requesting topics…
[ERROR] [1683900517.620395]: Tried to publish before configured, topic id 131
[INFO] [1683900517.628755]: Requesting topics…
[ERROR] [1683900517.726996]: Tried to publish before configured, topic id 131
[INFO] [1683900517.736757]: Requesting topics…
[ERROR] [1683900517.832256]: Tried to publish before configured, topic id 131
[INFO] [1683900517.841942]: Requesting topics…
[ERROR] [1683900517.938394]: Tried to publish before configured, topic id 131
[INFO] [1683900517.946741]: Requesting topics…
[ERROR] [1683900518.044103]: Tried to publish before configured, topic id 131
[INFO] [1683900518.052497]: Requesting topics…
[ERROR] [1683900518.150921]: Tried to publish before configured, topic id 131
[INFO] [1683900518.159199]: Requesting topics…
[ERROR] [1683900518.256355]: Tried to publish before configured, topic id 131
[INFO] [1683900518.268796]: Requesting topics…
[ERROR] [1683900518.363236]: Tried to publish before configured, topic id 131
[INFO] [1683900518.372053]: Requesting topics…
[ERROR] [1683900518.468915]: Tried to publish before configured, topic id 131
[INFO] [1683900518.477276]: Requesting topics…
[ERROR] [1683900518.575635]: Tried to publish before configured, topic id 131
[INFO] [1683900518.583779]: Requesting topics…
[ERROR] [1683900518.681004]: Tried to publish before configured, topic id 131
[INFO] [1683900518.688285]: Requesting topics…
[ERROR] [1683900518.788034]: Tried to publish before configured, topic id 131
[INFO] [1683900518.796459]: Requesting topics…
[ERROR] [1683900518.892877]: Tried to publish before configured, topic id 131
[INFO] [1683900518.901203]: Requesting topics…
[ERROR] [1683900518.999357]: Tried to publish before configured, topic id 131
[INFO] [1683900519.007996]: Requesting topics…
[ERROR] [1683900519.105942]: Tried to publish before configured, topic id 131
[INFO] [1683900519.114193]: Requesting topics…
[ERROR] [1683900519.210918]: Tried to publish before configured, topic id 131
[INFO] [1683900519.219976]: Requesting topics…
[ERROR] [1683900519.317809]: Tried to publish before configured, topic id 131
[INFO] [1683900519.325730]: Requesting topics…
[ERROR] [1683900519.423393]: Tried to publish before configured, topic id 131
[INFO] [1683900519.431180]: Requesting topics…
[ERROR] [1683900519.528815]: Tried to publish before configured, topic id 131
[INFO] [1683900519.537341]: Requesting topics…
[ERROR] [1683900519.635484]: Tried to publish before configured, topic id 131
[INFO] [1683900519.643493]: Requesting topics…
[ERROR] [1683900519.741331]: Tried to publish before configured, topic id 131
[INFO] [1683900519.750513]: Requesting topics…
[ERROR] [1683900519.847476]: Tried to publish before configured, topic id 131
[INFO] [1683900519.856041]: Requesting topics…
[ERROR] [1683900519.953346]: Tried to publish before configured, topic id 131
[INFO] [1683900519.961526]: Requesting topics…
[ERROR] [1683900520.059836]: Tried to publish before configured, topic id 131
[INFO] [1683900520.068238]: Requesting topics…
[ERROR] [1683900520.166660]: Tried to publish before configured, topic id 131
[INFO] [1683900520.175626]: Requesting topics…
[ERROR] [1683900520.271887]: Tried to publish before configured, topic id 131
[INFO] [1683900520.280701]: Requesting topics…
[ERROR] [1683900520.378589]: Tried to publish before configured, topic id 131
[INFO] [1683900520.387222]: Requesting topics…
[ERROR] [1683900520.484359]: Tried to publish before configured, topic id 131
[INFO] [1683900520.493086]: Requesting topics…
[ERROR] [1683900520.590338]: Tried to publish before configured, topic id 131
[INFO] [1683900520.601810]: Requesting topics…
[ERROR] [1683900520.696205]: Tried to publish before configured, topic id 131
[INFO] [1683900520.707582]: Requesting topics…
[ERROR] [1683900520.803065]: Tried to publish before configured, topic id 131
[INFO] [1683900520.811908]: Requesting topics…
[ERROR] [1683900520.908197]: Tried to publish before configured, topic id 131
[INFO] [1683900520.916443]: Requesting topics…
[ERROR] [1683900521.014306]: Tried to publish before configured, topic id 131
[INFO] [1683900521.022191]: Requesting topics…
[ERROR] [1683900521.121219]: Tried to publish before configured, topic id 131
[INFO] [1683900521.129365]: Requesting topics…
[ERROR] [1683900521.227399]: Tried to publish before configured, topic id 131
[INFO] [1683900521.235855]: Requesting topics…
[ERROR] [1683900521.333848]: Tried to publish before configured, topic id 131
[INFO] [1683900521.341993]: Requesting topics…
[ERROR] [1683900521.439842]: Tried to publish before configured, topic id 131
[INFO] [1683900521.448417]: Requesting topics…
[ERROR] [1683900521.546689]: Tried to publish before configured, topic id 131
[INFO] [1683900521.556238]: Requesting topics…
[ERROR] [1683900521.651885]: Tried to publish before configured, topic id 131
[INFO] [1683900521.660089]: Requesting topics…
[ERROR] [1683900521.758190]: Tried to publish before configured, topic id 131
[INFO] [1683900521.766633]: Requesting topics…
[ERROR] [1683900521.863825]: Tried to publish before configured, topic id 131
[INFO] [1683900521.872302]: Requesting topics…
[ERROR] [1683900521.970611]: Tried to publish before configured, topic id 131
[INFO] [1683900521.979039]: Requesting topics…
[ERROR] [1683900522.075222]: Tried to publish before configured, topic id 131
[INFO] [1683900522.085348]: Requesting topics…
[ERROR] [1683900522.182034]: Tried to publish before configured, topic id 131
[INFO] [1683900522.191419]: Requesting topics…
[ERROR] [1683900522.287741]: Tried to publish before configured, topic id 131
[INFO] [1683900522.296138]: Requesting topics…
^C[turtlebot3_diagnostics-3] killing on exit
[turtlebot3_lds-2] killing on exit
[turtlebot3_core-1] killing on exit
[INFO] [1683900522.375562]: Sending tx stop request
[INFO] [1683900522.383736]: shutdown hook activated
^C[turtlebot3_lds-2] escalating to SIGTERM
shutting down processing monitor…
… shutting down processing monitor complete
done
Thank you
Shivam
