Use the following template to help create your pos
State the model of servo, or ROBOTIS edutainment kit, you are using.
Specify which software you are using. Tag your post with the relevant software (or create a tag). (Note: “R+” is written in tags as “Rplus”)
Describe your control environment. This includes the controller or interface, operating system (and version #) of your computer, and any power source you are using.
For programming posts, state any libraries or example code you are using.
To whom it may concern, I have the bioloid premium robot kit, and had to rebuild it.
So, everything is connected but when I go into the robo manager I see all the servos
but when I press all the buttons in back of the robots controller the robot I hear the sounds as the robot tries to get out of its crouching position, but can’t stand straight up. Can anyone help me out thank you, Mike.
