I would like to make a motion suit robot using two CM-700 controllers. The BT-410 module was used to wirelessly connect the controller to the controller. It appears to have been paired, but virtually no built-in code is executed. Is there any solution or other Bluetooth connection that BT-410 can connect to each other?
AX-12A
RX-24F
CM-700 x 2
task1.0
