Hello everyone. I have a question regarding my Darwin-OP. It seems that I cannot run the demo program after turning it on. I’ve tried running it manually by using the terminal but it keeps showing error : Cannot identify ‘/dev/vedio0’: 2, No such file or directory. This problem happens after I tried Clonezilla Recovery. How can I fix this issue? Thanks
Check back the demo program file and double check the wiring on camera
That means it cannot find the head camera. Check its cable. Also try use another program like Cheese to view this camera.
You can try to plug an USB webcam at the back before to start Darwin. Then the demo program should start. if so, it means that you probably have embedded head camera trouble. I hope for you this is only connection troubles, if not, you’ll have to change the camera.
