ROBOTIS Software
(What ROBOTIS program are you using?)
R+Block
Control Environment
(Describe your robot’s control environment. This includes the PC (operating system & version) or other controller as well as the power supply you are using.)
Android device
Software Description
(A detailed description of the program that you are attempting to write, and what is is intended to achieve. Be sure to specify any included libraries or other third party tools or resources used.)
Blocks for CM-50 (OLLO K)
Issue Description
(A detailed discription of the issue you are experienceing, along with any error messages or other information you may have. The more information you share the more likely it is that somebody can help)
Can we change the speed of motors for “Move forward” and other action for CM-50 (OLLO K) in R+Block? The default speed is really slow…
(Photographs, debug logs, videos or other additional resources, If you don’t have any you may remove this section.)
