DYNAMIXEL Servo: AX-12A
DYNAMIXEL Controller: Arbotix-m and U2D2
Software Interface: Dynamixel Wizard 2.0
I just test my arm robot with ax-12a servo but the servo can’t connect to dynamixel wizard 2.0 , I use 7 servo for my arm robot, the arbotix just supply the servo. I just wan’t to now my servo id(Sometimes dynamixel wizard can read,but sometimes dynamixel wizard can’t read). In addition, if you have solution to read my id with just using arbotix board that’s will solve my other case too.
I will put my wiring on the bottom
The black connector for ax-12a and the white connector is for u2d2. I hope it can solve quickly hehe
