Error Installing Camera Library for OpenManipulator-X on ROS Noetic
Hello
I’m working with OpenManipulator-X on Ubuntu 20.04 with ROS Noetic and RealSense camera support. I’m facing an issue while trying to install the camera library. This problem also there when I was using Ubuntu 16.04 previously.
When trying to download the camera library, I’m facing installation failures. Despite trying all these different methods, the installation process consistently fails.
I’ve tried to install the necessary ROS packages for RealSense camera support using the sudo apt-get install ros-noetic-realsense2-camera command, but the issue still there . I’ve also ensured that ROS Noetic is set up correctly on my Ubuntu 20.04 system. Robotics Talk - ROBOTIS view
I’m seeking help on how to proceed with resolving this error and successfully installing the camera library for OpenManipulator-X on ROS Noetic.
Any suggestion would be greatly appreciated.
Thank you
stevediaz
