When I try to Teleop Turtlebot3 Burger using Keyboard of a Remote PC,
the following error appear
Failed to open the serial port /dev/ttyACM0
Any advice
Any advice
This message indicates that you aren’t able to access the configured serial port you are attempting to use for teleoperation. the most likely causes for this are:
Hi, I have more information on the error.
Turtlebot3 bring-up is successful.
Teleop is able to launch.
Using W A S D keys , on PC terminal side, it show the data changing
But the robot failed to move.
Here is the error
Error opening serial: [Errno 2] could not open port /dev/ttyACM0: [Errno 2] No such file or directory "/dev/ttyACM0
How to check where is above file?
Are you executing bringup on a Raspberry Pi4B?
Also, try executing
$ ls -l /dev/ttyACM0
on a Raspberry Pi4B to check the permissions.
