Connect GS-12 to Opencm9.04 board ports 1 and 2.
Attach GS-12 to a flat surface for calibration.
Upload Gyro_XY_Read from ROBOTIS_OpenCM IDE sensor examples.
Open Serial Monitor.
X,Y Readings from sketch print statements never vary when rotating sensor.
Same result if I use Arduino IDE
If I connect a DMS-80 to Opencm9.04 port 1 and Upload OLLO DMS Read, reading varies as objects get closer.
Does this indicate the GS-12 is faulty or is there something I am missing?
XL-320 (none connected during this test, power batteries disconnected)
OpenCm9.04
ROBOTIS_OpenCM IDE, Arduino IDE
