Microcontroller
Open-RB150
Software Description
Arduino IDE
Issue Description
When I use the example code for “position control” with a potentiometer. I must open the “Serial Monitor” before controlling, i.e. open “Serial Monitor” first and then rotate the potentiometer . Otherwise, without opening “Serial Monitor”, Open-RB150 does not read the potentiometer signal.
Here is the example code:
- Copyright 2016 ROBOTIS CO., LTD.
- Licensed under the Apache License, Version 2.0 (the “License”);
- you may not use this file except in compliance with the License.
- You may obtain a copy of the License at
http://www.apache.org/licenses/LICENSE-2.0 - Unless required by applicable law or agreed to in writing, software
- distributed under the License is distributed on an “AS IS” BASIS,
- WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
- See the License for the specific language governing permissions and
- limitations under the License.
#include <SoftwareSerial.h>
#define DXL_SERIAL Serial
#define DXL_SERIAL Serial1
#define DXL_SERIAL Serial3 //OpenCM9.04 EXP Board’s DXL port Serial. (Serial1 for the DXL port on the OpenCM 9.04 board)
const int DXL_DIR_PIN = 22; //OpenCM9.04 EXP Board’s DIR PIN. (28 for the DXL port on the OpenCM 9.04 board)
// For OpenCR, there is a DXL Power Enable pin, so you must initialize and control it.
// Reference link : OpenCR/arduino/opencr_arduino/opencr/libraries/DynamixelSDK/src/dynamixel_sdk/port_handler_arduino.cpp at master · ROBOTIS-GIT/OpenCR · GitHub
const int DXL_DIR_PIN = 84; // OpenCR Board’s DIR PIN.
const int DXL_DIR_PIN = -1;
#endif
const uint8_t DXL_ID = 1;
DEBUG_SERIAL.begin(115200);
while(!DEBUG_SERIAL);
dxl.begin(57600);
// Get DYNAMIXEL information
dxl.ping(DXL_ID);
dxl.torqueOff(DXL_ID);
dxl.torqueOn(DXL_ID);
dxl.writeControlTableItem(PROFILE_VELOCITY, DXL_ID, 30);
// Please refer to e-Manual(DYNAMIXEL Shield) for available range of value.
int i_present_position = 0;
delay(1000);
while (abs(5.7 - f_present_position) > 2.0)
delay(1000);
