Manipulator P movements failure
se the following template to help create your post:
    Open Manipulator P
    Ubunto 18.04, ROS melodic, 24DC, u2d2 (attched to the arm), 1ms latency, 1000000baudrate
    ROS MoveIt Joint trajectory controller
[ERROR] - /omp_control_node: [TxRxResult] Incorrect status packet!
[ERROR] - /omp_control_node: groupSyncRead getdata failed
[ INFO] - /move_group_commander_wrappers_1657456265950814301: ABORTED: Solution found but controller failed during execution
A year ago, we bought a new Open Manipulator P and we have experiment with it since then and everything worked fine up to last week with the same configuration .
Last week, while working with the arm, I started to get fault messages during random movement that occurs at random times , which results in alot of movement failure
I have tried different latency, switching to another U2D2, different USB cable, different PC and non of them worked.
