import os
if os.name == ‘nt’:
import msvcrt
def getch():
return msvcrt.getch().decode()
else:
import sys, tty, termios
fd = sys.stdin.fileno()
old_settings = termios.tcgetattr(fd)
def getch():
try:
tty.setraw(sys.stdin.fileno())
ch = sys.stdin.read(1)
finally:
termios.tcsetattr(fd, termios.TCSADRAIN, old_settings)
return ch
from dynamixel_sdk import * # Uses Dynamixel SDK library
Control table address
ADDR_PRO_TORQUE_ENABLE = 64
ADDR_MX_GOAL_VELOCITY = 104
ADDR_MX_PRESENT_POSITION = 132
Data Byte Length
LEN_MX_GOAL_VELOCITY = 4
LEN_MX_PRESENT_POSITION = 4
Protocol version
PROTOCOL_VERSION = 1.0 # See which protocol version is used in the Dynamixel
Default setting
DXL1_ID = 1 # Dynamixel#1 ID : 1
BAUDRATE = 57600 # Dynamixel default baudrate : 57600
DEVICENAME = ‘COM4’ # Check which port is being used on your controller
# ex) Windows: “COM1” Linux: “/dev/ttyUSB0” Mac: “/dev/tty.usbserial-*”
DXL_MINIMUM_POSITION_VALUE = 100 # Dynamixel will rotate between this value
DXL_MAXIMUM_POSITION_VALUE = 4000 # and this value (note that the Dynamixel would not move when the position value is out of movable range. Check e-manual about the range of the Dynamixel you use.)
DXL_MOVING_STATUS_THRESHOLD = 20 # Dynamixel moving status threshold
index = 0
dxl_goal_velocity = [DXL_MINIMUM_POSITION_VALUE, DXL_MAXIMUM_POSITION_VALUE] # Goal position
Initialize PortHandler instance
Set the port path
Get methods and members of PortHandlerLinux or PortHandlerWindows
Initialize PacketHandler instance
Set the protocol version
Get methods and members of Protocol1PacketHandler or Protocol2PacketHandler
packetHandler = PacketHandler(PROTOCOL_VERSION)
Initialize GroupBulkRead instace for Present Position
groupBulkRead = GroupBulkRead(portHandler, packetHandler)
Initialize GroupSyncWrite instance
groupSyncWrite = GroupSyncWrite(portHandler, packetHandler, ADDR_MX_GOAL_VELOCITY, LEN_MX_GOAL_VELOCITY)
Open port
if portHandler.openPort():
print(“Succeeded to open the port”)
else:
print(“Failed to open the port”)
print(“Press any key to terminate…”)
getch()
quit()
Set port baudrate
print(“Succeeded to change the baudrate”)
else:
print(“Failed to change the baudrate”)
getch()
quit()
Enable Dynamixel#1 Torque
dxl_comm_result, dxl_error = packetHandler.write1ByteTxRx(portHandler, DXL1_ID, ADDR_PRO_TORQUE_ENABLE, TORQUE_ENABLE)
print(“%s” % packetHandler.getTxRxResult(dxl_comm_result))
elif dxl_error != 0:
print(“%s” % packetHandler.getRxPacketError(dxl_error))
else:
print(“Dynamixel#%d has been successfully connected” % DXL1_ID)
Add parameter storage for Dynamixel#1 present position
dxl_addparam_result = groupBulkRead.addParam(DXL1_ID, ADDR_MX_PRESENT_POSITION, LEN_MX_PRESENT_POSITION)
if dxl_addparam_result != True:
print(“[ID:%03d] groupBulkRead addparam failed” % DXL1_ID)
quit()
while 1:
print(“Press any key to continue! (or press ESC to quit!)”)
if getch() == chr(0x1b):
break
param_goal_velocity = [DXL_LOBYTE(DXL_LOWORD(dxl_goal_velocity[index])), DXL_HIBYTE(DXL_LOWORD(dxl_goal_velocity[index])), DXL_LOBYTE(DXL_HIWORD(dxl_goal_velocity[index])), DXL_HIBYTE(DXL_HIWORD(dxl_goal_velocity[index]))]
# Add Dynamixel#1 goal position value to the Syncwrite parameter storage
dxl_addparam_result = groupSyncWrite.addParam(DXL1_ID, param_goal_velocity)
print("[ID:%03d] groupSyncWrite addparam failed" % DXL1_ID)
quit()
# Syncwrite goal position
dxl_comm_result = groupSyncWrite.txPacket()
# Clear syncwrite parameter storage
groupSyncWrite.clearParam()
while 1:
# Bulkread present position and moving status
dxl_comm_result = groupBulkRead.txRxPacket()
# Check if groupbulkread data of Dynamixel#1 is available
dxl_getdata_result = groupBulkRead.isAvailable(DXL1_ID, ADDR_MX_PRESENT_POSITION, LEN_MX_PRESENT_POSITION)
if dxl_getdata_result != True:
print("[ID:%03d] groupBulkRead getdata failed" % DXL1_ID)
quit()
# Get Dynamixel#1 present position value
dxl1_present_position = groupBulkRead.getData(DXL1_ID, ADDR_MX_PRESENT_POSITION, LEN_MX_PRESENT_POSITION)
print("[ID:%03d] GoalPos:%03d PresPos:%03d" % (DXL1_ID, dxl_goal_velocity[index], dxl1_present_position))
if not ((abs(dxl_goal_velocity[index] - dxl1_present_position) > DXL_MOVING_STATUS_THRESHOLD) ):
break
# Change goal position
if index == 0:
index = 1
else:
index = 0
Clear syncread parameter storage
groupBulkRead.clearParam()
Disable Dynamixel#1 Torque
dxl_comm_result, dxl_error = packetHandler.write1ByteTxRx(portHandler, DXL1_ID, ADDR_PRO_TORQUE_ENABLE, TORQUE_DISABLE)
Close port
portHandler.closePort()
Model of servo: MX-64T
Dynamixel wizard 2.0 and Rplus manager
I want to run motor goal_velocity instead of goal_position . i have attached the code kindly help me to correct this code, because by this code my motor run continuesly with constant speed.
