I purchased a raspberry Pi 3B+ to replace a board that had failed in a Turtlebot3.
I downloaded the tb3_rpi3b+_kinetic_20220513.img and used the Raspberry Pi Imager to copy to an SMD.
After the SMD was inserted, RPI did not boot, and I got 4 long flashes and 7 short flashes, indicating a problem with the img.
I checked by inserting the SMD into another older Turtlebot3 and it booted fine.
Using Raspberry Pi imager I downloaded Raspian to an SMD and it boots in the newer RPI fine.
My conclusion is that the software on the robotis website is perhaps not up to date as per
this link Newly purchased RPI 3B+ wont boot from older image - Raspberry Pi Forums
has anyone else seen the problem and have a solution for it?
many thanks
