What model(s) of servo are you using?
xl330-m077-t, XM430-W210-T -
Describe your control environment. Include the controller or interface, operating system (and version #) of your computer, and how you are powering your robot.
OpenCM 9.04 C-type
For programming posts, state any libraries or example code you are using. For software posts, be clear about which version of software! R+ Task 3.0, R+ Task 2.0, and RoboPlus Task (“1.0”) can have very different troubleshooting steps, as just one example.
Remember to mark your post Solved when applicable!
Hello, I am trying to control XL330-M077-T and XM430-W210-T together with an OpenCM 9.04 board. I will power both motors with separate power sources and try to connect them using TTL communication. Here are my questions:
Can the OpenCM board control XL and XM motors without an expansion board?
Is it better to use an Arduino MKR + Dynamixel Shield?
Is OPENRB-150 the board can substitute Arduino MKR + Dynamixel Shield? Do I need a OPENRB-150 board only to control both XL330-M077-T and XM430-W210-T motors together?
Does OPENRB-150 have Bluetooth connectivity?
What is difference between OpenCM board and OPENRB-150 board?
