How to use software serial on OpenRB-150? I am trying to make OpenRB-150 communicate with PC through ESP8266-01, which works well with the Arduino UNO. I tried to include the software serial library, but it seems to be lack of some dependencies.
Yes, using Serial Communications on OpenRB-150 does require some more setup, you can read more details in the free Amazon Kindle sample of my Arduino book which is available here:
https://www.amazon.com/Using-ARDUINO-ROBOTIS-Systems-Ngoc-ebook/dp/B0BPXGQ6YX/
See Chapter 2, Sections 2.3 and 2.4.
Hi. I have also one problm with. I use OpenRB with Arduino IDE.
After uploading of sample sketch position_mode controller does not start and Dynamixel power led is not on. Wenn I use Dynamixel Wizard and do scan option, after this the controller works properly. Any tipps? Thanks
@Aleduino
Your issue got nothing to do with this Software Serial Support topic. Please create a NEW TOPIC for your own issue.
