Is there a way to run r+ task 3.0 on Ubuntu?
I don’t use Ubuntu, so this is only a guess. This link shows how to create a Virtual Windows 10 on Ubuntu.
As TASK 3 is a Windows Application, so maybe then you can install TASK 3 in that Virtual Box? Or maybe TASK 2? What kind of ROBOTIS Controllers do you plan to use: CM-530, CM-550?
Have you considered using Dynamixel SDK on Linux?
I’ve got good results using DXL SDK on RPi-4B.
I’m using cm530 and was hoping to be able to use r+ task without virtual machine.
Taking another approach, TASK 3 is also available as an Android App
Can you setup your Ubuntu box to run Android Apps and Games?
https://www.makeuseof.com/tag/run-android-apps-games-linux/
https://www.xda-developers.com/waydroid-android-apps-on-linux/
