Hello everyone,
I am currently going through the tutorials listed here for simulation use of the OpenManipulator-X. As stated by the tutorial, when you run rostopic list you should get:
/clock
/gazebo/link_states
/gazebo/model_states
/gazebo/parameter_descriptions
/gazebo/parameter_updates
/gazebo/set_link_state
/gazebo/set_model_state
/gazebo_gui/parameter_descriptions
/gazebo_gui/parameter_updates
/gazebo_ros_control/pid_gains/gripper/parameter_descriptions
/gazebo_ros_control/pid_gains/gripper/parameter_updates
/gazebo_ros_control/pid_gains/gripper/state
/gazebo_ros_control/pid_gains/gripper_sub/parameter_descriptions
/gazebo_ros_control/pid_gains/gripper_sub/parameter_updates
/gazebo_ros_control/pid_gains/gripper_sub/state
/gazebo_ros_control/pid_gains/joint1/parameter_descriptions
/gazebo_ros_control/pid_gains/joint1/parameter_updates
/gazebo_ros_control/pid_gains/joint1/state
/gazebo_ros_control/pid_gains/joint2/parameter_descriptions
/gazebo_ros_control/pid_gains/joint2/parameter_updates
/gazebo_ros_control/pid_gains/joint2/state
/gazebo_ros_control/pid_gains/joint3/parameter_descriptions
/gazebo_ros_control/pid_gains/joint3/parameter_updates
/gazebo_ros_control/pid_gains/joint3/state
/gazebo_ros_control/pid_gains/joint4/parameter_descriptions
/gazebo_ros_control/pid_gains/joint4/parameter_updates
/gazebo_ros_control/pid_gains/joint4/state
/open_manipulator/gripper_position/command
/open_manipulator/gripper_sub_position/command
/open_manipulator/joint1_position/command
/open_manipulator/joint2_position/command
/open_manipulator/joint3_position/command
/open_manipulator/joint4_position/command
/open_manipulator/joint_states
/rosout
/rosout_agg
I am following the tutorial exactly, but am missing all topics under /gazebo_ros_control/pid_gains
Does anyone have and ideas?
