Turtlebot3 Manipulation - Manipulation Bringup constantly crash
I’m runing Turtblebot3 Manipulation with OpenManipulator-X.
The following commands were called:
roscore
$ roslaunch turtlebot3_bringup turtlebot3_robot.launch
$ roslaunch turtlebot3_manipulation_bringup turtlebot3_manipulation_bringup.launch
$ roslaunch turtlebot3_manipulation_moveit_config move_group.launch
$ roslaunch turtlebot3_manipulation_gui turtlebot3_manipulation_gui.launch
It works fine at the beginning, but quickly the manipulation_bringup start constantly crashing and the following error information is found in logs:
[rosmaster.master][INFO] 2024-04-25 18:58:53,341: publisherUpdate[/arm_controller/follow_joint_trajectory/goal] → http://172.26.174.94:36755/ : sec=0.00, exception=[Errno 111] Connection refused
[rosmaster.master][INFO] 2024-04-25 18:58:53,344: publisherUpdate[/execute_trajectory/result] → http://172.26.174.94:33081/ : sec=0.00, exception=[Errno 111] Connection refused
[rosmaster.threadpool][ERROR] 2024-04-25 18:58:53,349: Traceback (most recent call last):
File “/opt/ros/noetic/lib/python3/dist-packages/rosmaster/threadpool.py”, line 218, in run
result = cmd(*args)
File “/opt/ros/noetic/lib/python3/dist-packages/rosmaster/master_api.py”, line 210, in publisher_update_task
ret = xmlrpcapi(api).publisherUpdate(‘/master’, topic, pub_uris)
File “/usr/lib/python3.8/xmlrpc/client.py”, line 1109, in call
return self.__send(self.__name, args)
File “/usr/lib/python3.8/xmlrpc/client.py”, line 1450, in __request
response = self.__transport.request(
File “/usr/lib/python3.8/xmlrpc/client.py”, line 1153, in request
return self.single_request(host, handler, request_body, verbose)
File “/usr/lib/python3.8/xmlrpc/client.py”, line 1165, in single_request
http_conn = self.send_request(host, handler, request_body, verbose)
File “/usr/lib/python3.8/xmlrpc/client.py”, line 1278, in send_request
self.send_content(connection, request_body)
File “/usr/lib/python3.8/xmlrpc/client.py”, line 1308, in send_content
connection.endheaders(request_body)
File “/usr/lib/python3.8/http/client.py”, line 1251, in endheaders
self._send_output(message_body, encode_chunked=encode_chunked)
File “/usr/lib/python3.8/http/client.py”, line 1011, in _send_output
self.send(msg)
File “/usr/lib/python3.8/http/client.py”, line 951, in send
self.connect()
File “/usr/lib/python3.8/http/client.py”, line 922, in connect
self.sock = self._create_connection(
File “/usr/lib/python3.8/socket.py”, line 808, in create_connection
raise err
File “/usr/lib/python3.8/socket.py”, line 796, in create_connection
sock.connect(sa)
ConnectionRefusedError: [Errno 111] Connection refused
My setup is OpenCR 1.0, and Intel NUC 11 serves as both the master PC and SBC. The ROS Version is Noetic.
The cause of this error may be due to an inappropriate routing setting or the presence of a firewall on the network. It is also possible that the communication within the LAN is unstable and communication is not being carried out properly. Please check the LAN communication.
