Hello everyone, I currently have 2 U2D2 devices in my hands (one of which was recently purchased and has not exceeded 3 months). I am searching for a steering gear, as shown in the figure:
A phenomenon has occurred:
A U2D2 can search for the steering gear (normal),
Another one cannot be searched (abnormal)
The equipment I debugged is as follows:
12V 5A power adapter
U2D2+U2D2 Power Hub
Android data cables (all purchased in original packaging)
Known conditions: The same line and power supply equipment, the same steering gear, and the same settings (including baud rate) result in one being searchable and the other not.
Can it be the problem of communication chip damage? There have been no quality issues with U2D2 products before, and this time it’s strange. Let’s infer which part of the problem has occurred.
There is no problem with DXL itself. The current issue is that U2D2 cannot search. You may have misunderstood my meaning. It would be great if you could upload a video here, as the video may be clearer to watch
Sorry that I misunderstood your wording. You said “cannot be searched” instead of “cannot search” so I thought that you were referring to a DXL instead of a U2D2. If the problem is a U2D2 there is not much that an end user can do. Hopefully it is the new U2D2 unit so that you can do an RMA process with ROBOTIS. @ROBOTISUSA can help you.
@kay880
As @roboteer said, there’s not much that you’ll be able to repair yourself inside a U2D2 unit.
If the unit that’s giving you these issues is new, there’s a possibility that it might be covered under warranty. If it’s an older unit though, it would probably cost you more to send it in for repairs than it would be to just purchase a replacement.
