roboplus manager와는 conect가 되지만 roboplus task와는 로봇이 연결이 안 되는 데 어떡하나요?
As both MANAGER and TASK tools use the same COM Port on your PC, so they CANNOT both be used at the same time. You need to exit from one tool completely before you can use the other tool.
Thank you very so much!!
