State the model of servo you are using.
AX-12 servos To whom it may concern I would like to know why when I press the play button on the back of the robot it stands, hit top button on the cm530 my bot does a split. The upper body everything is ok, but not the bottom and everything is fixed right. So, please help me out thank you, Jerseylance. -
Add (or create) Tags to your post with the specific model of your product.
Describe your control environment. This includes the controller or interface, computer and OS, and any power source you are using
Specify the operating mode you are using, for applicable models.
Specify and link any manuals or resources you have used related to your inquiry.
Include pictures if possible. This can help our members see how wires are connected, how hardware is installed, or to identify other possible issues.
