@roboteer Thank you so much. Please toss me this thread. ROBOTIS really appreciate your effort and time.
Hi @Jerseylance1.
Seems that @roboteer who is one of the power user in this community has given you lots of advices and tips on how to trobleshoot.
If you have a problem with newely purchased CM-530, and does not correctly perform programmed motions (R+Motion).
I found out your old controller has no issue to perform programmed motions when you tested the one.
It means that the motion program itself has low possibility being a cause you should fix in this phase.
However, it is still worthy doing a troubleshooting step by step: Please install R+Task 3.0 and play other motion files with a differnt PC if possible
Here is the link:
DownloadROBOTIS -
Motion: R+ Task 3.0
if it does not work out the issue.
Please, send your controller in trouble and let us do some motion test with our test process.
