Commando 작동방법이 궁금합니다!
엔지니어 키트2에 있는 commando를 제작하였는데
프로그램을 어떤 걸 넣어야할까요?
제작은 하였는데 작동이 안되어 여쭈어봅니다!
그리고 엔지니어 키트3는 언제나올까요?
The COMMANDO uses Micro Python instead of the usual TASK code
Once you pull up this Python program, you just download it as normal to the CM-550 (via USB or BT-410 USB dongle - depending on the communication hardware that you have).
The COMMANDO also uses the ENGINEER Mobile App to control the robot. The ENGINEER App can be downloaded from Google Play Store or the Apple App Store.
Also there are free “user manuals” from ROBOTIS when you register your ENGINEER Kits.
https://www.robotis.com/model/login.php?url=/edu/engkit2.php
