Dynamixel servo XM430 W350 with random current readings
Issue: Random current readings and overload error
My dynamixel keeps showing high current readings that fluctuate to lower randomly and that triggers shutdown every time I set the torque on.
DYNAMIXEL Servo: XM430 W350
XM430 W350
DYNAMIXEL Controller: U2D2
U2D2
Software Interface: ROS 1, Dynamixel Wizard 2.0
High current readings and a shutdown on torque enable sounds like your actuator has been damaged.
