Hi folks,
In assembling my DYNAMIXEL XM540-W270-T drive side servo horn, I forgot to add the thrust washer. The splined shaft is a very tight fit on the horn, so I am afraid to try to remove it for fear of causing damage. My questions are:
Is it okay to run the servo without the thrust washer?
Is there a good way to pull the drive side horn off the splined drive shaft without causing damage?
Thank you!
Ihab
