Help! My DYNAMIXEL Servo isn't working! How can I fix it?
Don’t worry, we’re here to help! Here’s a step-by-step guide for diagnosing and addressing common issues with DYNAMIXEL servos:
  1. Check the Connections: Unplug any additional actuators connected to your DYNAMIXEL system to test a single one at a time. Ensure that the servo is properly connected to your control board, and the control board is correctly connected to your power source. Verify that the wiring is correct, and that all cables are securely plugged in.
  2. Power Check: Please ensure that your power supply provides the correct voltage for your specific servo model, and confirm that the red LED indicator light blinks once when the servo is connected to power. Always refer to your servo’s technical specifications to ensure it is receiving the correct voltage.
  3. Reset the Servo: If none of the above steps work, try resetting the servo to its factory defaults using the firmware reset functionality of the DYNAMIXEL Wizard 2.0 configuration software. Please note, resetting the servo will erase any custom settings.
  4. Contact Support: If you’ve tried the steps above and your servo still isn’t working, it might have a more serious problem. Please contact our technical support for further assistance at support@robotis.com.
Remember, regular maintenance, such as checking for loose screws and cables, or damaged parts can also help keep your servos in good working condition. Always feel free to reach out to the ROBOTIS community if you have any questions or need further assistance.
