OpenmanipulatorX SYNC_READ_FAIL
While following the e-Manual to use the OpenManipulator-X I tested this code [ros2 launch open_manipulator_x_bringup hardware.launch.py ]
and error occurred
[INFO] [launch]: All log files can be found below
/home/mecha4321/.ros/log/2025-07-30-16-47-42-727539-mecha4321-800G5H-800G5S-786
8
[INFO] [ros2_control_node-1]: process started with pid [7872]
[INFO] [robot_state_publisher-2]: process started with pid [7874]
[INFO] [spawner-3]: process started with pid [7876]
[robot_state_publisher-2] [INFO] [1753861663.269605681] [robot_state_publisher]: got
segment dummy_mimic_fix
[robot_state_publisher-2] [INFO] [1753861663.269737377] [robot_state_publisher]: got
segment end_effector_link
[robot_state_publisher-2] [INFO] [1753861663.269758880] [robot_state_publisher]: got
segment gripper_left_link
[robot_state_publisher-2] [INFO] [1753861663.269773714] [robot_state_publisher]: got
segment gripper_right_link
[robot_state_publisher-2] [INFO] [1753861663.269787711] [robot_state_publisher]: got
segment link1
[robot_state_publisher-2] [INFO] [1753861663.269801358] [robot_state_publisher]: got
segment link2
[robot_state_publisher-2] [INFO] [1753861663.269814909] [robot_state_publisher]: got
segment link3
[robot_state_publisher-2] [INFO] [1753861663.269828783] [robot_state_publisher]: got
segment link4
[robot_state_publisher-2] [INFO] [1753861663.269842567] [robot_state_publisher]: got
segment link5
[robot_state_publisher-2] [INFO] [1753861663.269856125] [robot_state_publisher]: got
segment world
[ros2_control_node-1] [WARN] [1753861663.310835719] [controller_manager]: [Deprecated]
Passing the robot description parameter directly to the control_manager node is deprecated.
Use ‘~/robot_description’ topic from ‘robot_state_publisher’ instead.
[ros2_control_node-1] [INFO] [1753861663.311315952] [resource_manager]: Loading
hardware ‘OpenManipulatorXSystem’
[ros2_control_node-1] [INFO] [1753861663.318728466] [resource_manager]: Initialize
[ros2_control_node-1] transmission_to_joint_matrix_
[ros2_control_node-1] [0][0] 1.000000, [0][1] 0.000000, [0][2] 0.000000, [0][3] 0.000000,
[0][4] 0.000000,
[ros2_control_node-1] [1][0] 0.000000, [1][1] 1.000000, [1][2] 0.000000, [1][3] 0.000000,
[1][4] 0.000000,
[ros2_control_node-1] [2][0] 0.000000, [2][1] 0.000000, [2][2] 1.000000, [2][3] 0.000000,
[2][4] 0.000000,
[ros2_control_node-1] [3][0] 0.000000, [3][1] 0.000000, [3][2] 0.000000, [3][3] 1.000000,
[3][4] 0.000000,
[ros2_control_node-1] [4][0] 0.000000, [4][1] 0.000000, [4][2] 0.000000, [4][3] 0.000000,
[4][4] 1.000000,
[ros2_control_node-1] [5][0] 0.000000, [5][1] 0.000000, [5][2] 0.000000, [5][3] 0.000000,
[5][4] 0.000000,
[ros2_control_node-1] joint_to_transmission_matrix_
[0][4] 0.000000, [0][5] 0.000000,
[1][4] 0.000000, [1][5] 0.000000,
[2][4] 0.000000, [2][5] 0.000000,
[3][4] 0.000000, [3][5] 0.000000,
[4][4] 1.000000, [4][5] 0.000000,
[ros2_control_node-1] [INFO] [1753861663.319420849] [dynamixel_hardware_interface]:
error_timeout_ms parameter not found, using default value of 500ms
[ros2_control_node-1] [INFO] [1753861663.319451407] [dynamixel_hardware_interface]: If
there is a torque enabled Dynamixel, the program will be terminated. Set
‘disable_torque_at_init’ parameter to ‘true’ to disable torque at initialization.
[ros2_control_node-1] [INFO] [1753861663.319472504] [dynamixel_hardware_interface]:
port_name /dev/ttyUSB0 / baudrate 1000000
[ros2_control_node-1] Dynamixel Information File List.
[ros2_control_node-1] num: 220, name: omy_hat.model
[ros2_control_node-1] num: 230, name: omy_end.model
[ros2_control_node-1] num: 231, name: omy_end_rh_p12_rn.model
[ros2_control_node-1] num: 350, name: xl320.model
[ros2_control_node-1] num: 536, name: sensorxel_joy.model
[ros2_control_node-1] num: 537, name: ffw_g40_imu.model
[ros2_control_node-1] num: 600, name: sensorxel_joy.model
[ros2_control_node-1] num: 601, name: ffw_g10_led.model
[ros2_control_node-1] num: 602, name: ffw_g10_rcu.model
[ros2_control_node-1] num: 620, name: ffw_sg2_steer_1.model
[ros2_control_node-1] num: 621, name: ffw_sg2_steer_2.model
[ros2_control_node-1] num: 622, name: ffw_sg2_steer_3.model
[ros2_control_node-1] num: 623, name: ffw_sg2_drive_1.model
[ros2_control_node-1] num: 624, name: ffw_sg2_drive_2.model
[ros2_control_node-1] num: 625, name: ffw_sg2_drive_3.model
[ros2_control_node-1] num: 1000, name: xh430_w350.model
[ros2_control_node-1] num: 1001, name: xd430_t350.model
[ros2_control_node-1] num: 1010, name: xh430_w210.model
[ros2_control_node-1] num: 1011, name: xd430_t210.model
[ros2_control_node-1] num: 1020, name: xm430_w350.model
[ros2_control_node-1] num: 1030, name: xm430_w210.model
[ros2_control_node-1] num: 1040, name: xh430_v350.model
[ros2_control_node-1] num: 1050, name: xh430_v210.model
[ros2_control_node-1] num: 1060, name: xl430_w250.model
[ros2_control_node-1] num: 1070, name: xc430_w150.model
[ros2_control_node-1] num: 1080, name: xc430_w240.model
[ros2_control_node-1] num: 1090, name: 2xl430_w250.model
[ros2_control_node-1] num: 1100, name: xh540_w270.model
[ros2_control_node-1] num: 1101, name: xd540_t270.model
[ros2_control_node-1] num: 1110, name: xh540_w150.model
[ros2_control_node-1] num: 1111, name: xd540_t150.model
[ros2_control_node-1] num: 1120, name: xm540_w270.model
[ros2_control_node-1] num: 1130, name: xm540_w150.model
[ros2_control_node-1] num: 1140, name: xh540_v270.model
[ros2_control_node-1] num: 1150, name: xh540_v150.model
[ros2_control_node-1] num: 1160, name: 2xc430_w250.model
[ros2_control_node-1] num: 1170, name: xw540_t260.model
[ros2_control_node-1] num: 1180, name: xw540_t140.model
[ros2_control_node-1] num: 1190, name: xl330_m077.model
[ros2_control_node-1] num: 1200, name: xl330_m288.model
[ros2_control_node-1] num: 1210, name: xc330_t181.model
[ros2_control_node-1] num: 1220, name: xc330_t288.model
[ros2_control_node-1] num: 1230, name: xc330_m181.model
[ros2_control_node-1] num: 1240, name: xc330_m288.model
[ros2_control_node-1] num: 1270, name: xw430_t333.model
[ros2_control_node-1] num: 1310, name: xw540_h260.model
[ros2_control_node-1] num: 2000, name: ph42_020_s300.model
[ros2_control_node-1] num: 4000, name: ym070_210_m001.model
[ros2_control_node-1] num: 4020, name: ym070_210_r051.model
[ros2_control_node-1] num: 4030, name: ym070_210_r099.model
[ros2_control_node-1] num: 4050, name: ym070_210_a099.model
[ros2_control_node-1] num: 4120, name: ym080_230_m001.model
[ros2_control_node-1] num: 4130, name: ym080_230_b001.model
[ros2_control_node-1] num: 4140, name: ym080_230_r051.model
[ros2_control_node-1] num: 4150, name: ym080_230_r099.model
[ros2_control_node-1] num: 4170, name: ym080_230_a099.model
[ros2_control_node-1] num: 35074, name: rh_p12_rn.model
[ros2_control_node-1] [INFO] [1753861663.320436214] [dynamixel_hardware_interface]:
[ros2_control_node-1] [INFO] [1753861663.320465431] [dynamixel_hardware_interface]:
$$$$$ Init Dxl Comm Port
[ros2_control_node-1] [INFO] [1753861663.320491660] [dynamixel_hardware_interface]:
Revolute to Prismatic gripper conversion enabled.
[ros2_control_node-1] [INFO] [1753861663.320711646] [dynamixel_hardware_interface]:
$$$$$ Init Items for type: controller
[ros2_control_node-1] [INFO] [1753861663.320750910] [dynamixel_hardware_interface]:
$$$$$ Init Items for type: virtual_dxl
[ros2_control_node-1] Succeeded to open the port!
[ros2_control_node-1] Succeeded to change the [1000000] baudrate!
[ros2_control_node-1] [ID:011] Request ping - Ping succeeded. Dynamixel model number
: 1020 (xm430_w350.model)
[ros2_control_node-1] [ID:012] Request ping - Ping succeeded. Dynamixel model number
[ros2_control_node-1] [ID:013] Request ping - Ping succeeded. Dynamixel model number
[ros2_control_node-1] [ID:014] Request ping - Ping succeeded. Dynamixel model number
[ros2_control_node-1] [ID:015] Request ping - Ping succeeded. Dynamixel model number
[ros2_control_node-1] [INFO] [1753861663.337006300] [dynamixel_hardware_interface]:
Trying to connect to the communication port…
[ros2_control_node-1] [InitTorqueStates][ID:011] Current torque state: OFF
[ros2_control_node-1] [InitTorqueStates][ID:012] Current torque state: OFF
[ros2_control_node-1] [InitTorqueStates][ID:013] Current torque state: OFF
[ros2_control_node-1] [InitTorqueStates][ID:014] Current torque state: OFF
[ros2_control_node-1] [InitTorqueStates][ID:015] Current torque state: OFF
[ros2_control_node-1] [INFO] [1753861663.342452447] [dynamixel_hardware_interface]:
$$$$$ Init Items for type: dxl
[ros2_control_node-1] [INFO] [1753861663.342516438] [dynamixel_hardware_interface]:
[ID:11] item_name:Return Delay Time data:0
[ros2_control_node-1] [INFO] [1753861663.343442696] [dynamixel_hardware_interface]:
[ID:11] item_name:Drive Mode data:0
[ros2_control_node-1] [INFO] [1753861663.344436920] [dynamixel_hardware_interface]:
[ID:11] item_name:Position D Gain data:100
[ros2_control_node-1] [INFO] [1753861663.345437608] [dynamixel_hardware_interface]:
[ID:11] item_name:Position I Gain data:100
[ros2_control_node-1] [INFO] [1753861663.346437524] [dynamixel_hardware_interface]:
[ID:11] item_name:Position P Gain data:800
[ros2_control_node-1] [INFO] [1753861663.347440852] [dynamixel_hardware_interface]:
[ID:11] item_name:Profile Velocity data:200
[ros2_control_node-1] [INFO] [1753861663.348447813] [dynamixel_hardware_interface]:
[ID:11] item_name:Profile Acceleration data:50
[ros2_control_node-1] [INFO] [1753861663.349454041] [dynamixel_hardware_interface]:
[ID:12] item_name:Return Delay Time data:0
[ros2_control_node-1] [INFO] [1753861663.350437272] [dynamixel_hardware_interface]:
[ID:12] item_name:Drive Mode data:0
[ros2_control_node-1] [INFO] [1753861663.351434679] [dynamixel_hardware_interface]:
[ID:12] item_name:Position D Gain data:100
[ros2_control_node-1] [INFO] [1753861663.352435761] [dynamixel_hardware_interface]:
[ID:12] item_name:Position I Gain data:100
[ros2_control_node-1] [INFO] [1753861663.353434500] [dynamixel_hardware_interface]:
[ID:12] item_name:Position P Gain data:800
[ros2_control_node-1] [INFO] [1753861663.354435842] [dynamixel_hardware_interface]:
[ID:12] item_name:Profile Velocity data:200
[ros2_control_node-1] [INFO] [1753861663.355431663] [dynamixel_hardware_interface]:
[ID:12] item_name:Profile Acceleration data:50
[ros2_control_node-1] [INFO] [1753861663.356454629] [dynamixel_hardware_interface]:
[ID:13] item_name:Return Delay Time data:0
[ros2_control_node-1] [INFO] [1753861663.357437813] [dynamixel_hardware_interface]:
[ID:13] item_name:Drive Mode data:0
[ros2_control_node-1] [INFO] [1753861663.358438820] [dynamixel_hardware_interface]:
[ID:13] item_name:Position D Gain data:100
[ros2_control_node-1] [INFO] [1753861663.359437408] [dynamixel_hardware_interface]:
[ID:13] item_name:Position I Gain data:100
[ros2_control_node-1] [INFO] [1753861663.360438275] [dynamixel_hardware_interface]:
[ID:13] item_name:Position P Gain data:800
[ros2_control_node-1] [INFO] [1753861663.361435937] [dynamixel_hardware_interface]:
[ID:13] item_name:Profile Velocity data:200
[ros2_control_node-1] [INFO] [1753861663.362409297] [dynamixel_hardware_interface]:
[ID:13] item_name:Profile Acceleration data:50
[ros2_control_node-1] [INFO] [1753861663.363450460] [dynamixel_hardware_interface]:
[ID:14] item_name:Return Delay Time data:0
[ros2_control_node-1] [INFO] [1753861663.364439191] [dynamixel_hardware_interface]:
[ID:14] item_name:Drive Mode data:0
[ros2_control_node-1] [INFO] [1753861663.365439106] [dynamixel_hardware_interface]:
[ID:14] item_name:Position D Gain data:100
[ros2_control_node-1] [INFO] [1753861663.366455604] [dynamixel_hardware_interface]:
[ID:14] item_name:Position I Gain data:100
[ros2_control_node-1] [INFO] [1753861663.367440059] [dynamixel_hardware_interface]:
[ID:14] item_name:Position P Gain data:800
[ros2_control_node-1] [INFO] [1753861663.368441083] [dynamixel_hardware_interface]:
[ID:14] item_name:Profile Velocity data:200
[ros2_control_node-1] [INFO] [1753861663.369447764] [dynamixel_hardware_interface]:
[ID:14] item_name:Profile Acceleration data:50
[ros2_control_node-1] [INFO] [1753861663.370456345] [dynamixel_hardware_interface]:
[ID:15] item_name:Return Delay Time data:0
[ros2_control_node-1] [INFO] [1753861663.371439001] [dynamixel_hardware_interface]:
$$$$$ Init Items for type: sensor
[ros2_control_node-1] [INFO] [1753861663.371467924] [dynamixel_hardware_interface]:
$$$$$ Init Dxl Read Items
[ros2_control_node-1] Dynamixel Read Type : sync read
[ros2_control_node-1] ID : 11, 12, 13, 14, 15,
[ros2_control_node-1] Read items : Present Position Present VelocityPresent Current
Torque Enable Present Input Voltage
[ros2_control_node-1] set fast sync read (indirect addr) : addr 634, size 13
[ros2_control_node-1] FastSyncRead handler set up successfully.
[ros2_control_node-1] Success to set SyncRead handler using indirect address
[ros2_control_node-1] [INFO] [1753861663.437693947] [dynamixel_hardware_interface]:
$$$$$ Init Dxl Write Items
[ros2_control_node-1] Dynamixel Write Type : sync write
[ros2_control_node-1] Write items : Goal Position
[ros2_control_node-1] set sync write (indirect addr) : addr 224, size 4
[ros2_control_node-1] Success to set SyncWrite handler using indirect address
[ros2_control_node-1] [INFO] [1753861663.465042762] [resource_manager]: Successful
initialization of hardware ‘OpenManipulatorXSystem’
[ros2_control_node-1] [INFO] [1753861663.465510957] [resource_manager]: ‘configure’
[ros2_control_node-1] [INFO] [1753861663.465533795] [resource_manager]: Successful
‘configure’ of hardware ‘OpenManipulatorXSystem’
[ros2_control_node-1] [INFO] [1753861663.465559916] [resource_manager]: ‘activate’
[ros2_control_node-1] [INFO] [1753861663.467964818] [dynamixel_hardware_interface]:
Sync joint state to command (joint: joint1, position, 2.41567 ← position, 2.41567
[ros2_control_node-1] [INFO] [1753861663.468015792] [dynamixel_hardware_interface]:
Sync joint state to command (joint: joint2, position, 1.08352 ← position, 1.08352
[ros2_control_node-1] [INFO] [1753861663.468029804] [dynamixel_hardware_interface]:
Sync joint state to command (joint: joint3, position, -1.17043 ← position, -1.17043
[ros2_control_node-1] [INFO] [1753861663.468041611] [dynamixel_hardware_interface]:
Sync joint state to command (joint: joint4, position, 0.607753 ← position, 0.607753
[ros2_control_node-1] [INFO] [1753861663.468052981] [dynamixel_hardware_interface]:
Sync joint state to command (joint: gripper_left_joint, position, 0.0276622 ← position,
0.0276622
[ros2_control_node-1] [INFO] [1753861663.468064490] [dynamixel_hardware_interface]:
Sync joint state to command (joint: gripper_right_joint, position, 0 ← position, 0
[ros2_control_node-1] [INFO] [1753861663.468205433] [dynamixel_hardware_interface]:
Enabling torque for Dynamixels
[ros2_control_node-1] [ID:011] Torque ON
[ros2_control_node-1] [ID:012] Torque ON
[ros2_control_node-1] [ID:013] Torque ON
[ros2_control_node-1] [ID:014] Torque ON
[ros2_control_node-1] [ID:015] Torque ON
[ros2_control_node-1] [INFO] [1753861663.473448241] [dynamixel_hardware_interface]:
Dynamixel Hardware Start!
[ros2_control_node-1] [INFO] [1753861663.473487337] [resource_manager]: Successful
‘activate’ of hardware ‘OpenManipulatorXSystem’
[ros2_control_node-1] [INFO] [1753861663.477923468] [controller_manager]: update rate is
100 Hz
[ros2_control_node-1] [INFO] [1753861663.477954408] [controller_manager]: Spawning
controller_manager RT thread with scheduler priority: 50
[ros2_control_node-1] [WARN] [1753861663.478079109] [controller_manager]: No real-time
kernel detected on this system. See
[Controller Manager — ROS2_Control: Rolling Jan 2026 documentation] for
details on how to enable realtime scheduling.
[ros2_control_node-1] FastSyncRead Rx Fail [Dxl Size : 5] [Error code : -3001]
[ros2_control_node-1] [ERROR] [1753861663.478181481] [dynamixel_hardware_interface]:
Communication Fail → SYNC_READ_FAIL
[ros2_control_node-1] [ERROR] [1753861663.478216185] [dynamixel_hardware_interface]:
Dynamixel Read Fail (Duration: 0.000639ms/500ms)
[ros2_control_node-1] [ERROR] [1753861663.478240910] [dynamixel_hardware_interface]:
Dynamixel Write Fail (Duration: 0.000639ms/500ms)
[ros2_control_node-1] [INFO] [1753861663.697567487] [controller_manager]: Loading
controller ‘joint_state_broadcaster’
[spawner-3] [INFO] [1753861663.735195888] [spawner_joint_state_broadcaster]: Loaded
[ros2_control_node-1] [INFO] [1753861663.736152783] [controller_manager]: Configuring
[ros2_control_node-1] [INFO] [1753861663.736267849] [joint_state_broadcaster]: ‘joints’ or
‘interfaces’ parameter is empty. All available state interfaces will be published
[spawner-3] [INFO] [1753861663.771934381] [spawner_joint_state_broadcaster]:
Configured and activated joint_state_broadcaster
[INFO] [spawner-3]: process has finished cleanly [pid 7876]
[INFO] [spawner-4]: process started with pid [7923]
[INFO] [spawner-5]: process started with pid [7925]
[ros2_control_node-1] [INFO] [1753861664.469851762] [controller_manager]: Loading
controller ‘arm_controller’
[ros2_control_node-1] [WARN] [1753861664.481245886] [arm_controller]: [Deprecated]:
“allow_nonzero_velocity_at_trajectory_end” is set to true. The default behavior will change
to false.
[ros2_control_node-1] [INFO] [1753861664.506200219] [controller_manager]: Loading
controller ‘gripper_controller’
[spawner-5] [INFO] [1753861664.521041178] [spawner_arm_controller]: Loaded
arm_controller
[ros2_control_node-1] [INFO] [1753861664.522138360] [controller_manager]: Configuring
[ros2_control_node-1] [INFO] [1753861664.522396374] [arm_controller]: No specific joint
names are used for command interfaces. Using ‘joints’ parameter.
[ros2_control_node-1] [INFO] [1753861664.522436587] [arm_controller]: Command
interfaces are [position] and state interfaces are [position velocity].
[ros2_control_node-1] [INFO] [1753861664.522490336] [arm_controller]: Using ‘splines’
interpolation method.
[ros2_control_node-1] [INFO] [1753861664.523480068] [arm_controller]: Controller state will
be published at 200.00 Hz.
[ros2_control_node-1] [INFO] [1753861664.525466136] [arm_controller]: Action status
changes will be monitored at 20.00 Hz.
[spawner-4] [INFO] [1753861664.549949929] [spawner_gripper_controller]: Loaded
gripper_controller
[ros2_control_node-1] [INFO] [1753861664.551146412] [controller_manager]: Configuring
[ros2_control_node-1] [INFO] [1753861664.551215028] [gripper_controller]: Action status
changes will be monitored at 20.000000 Hz.
[spawner-5] [INFO] [1753861664.552114591] [spawner_arm_controller]: Configured and
activated arm_controller
[spawner-4] [INFO] [1753861664.582107339] [spawner_gripper_controller]: Configured and
activated gripper_controller
[INFO] [spawner-5]: process has finished cleanly [pid 7925]
[INFO] [spawner-4]: process has finished cleanly [pid 7923]
The same error [SYNC_READ_FAIL] keeps occurring. It is not an intermittent error, and the system is also not operating normally.
After running bringup, intermittent communication errors can occur due to noise. However, if the communication errors are persistent or if operations like teleoperation or MoveIt fail, there is a high probability of a hardware issue.
Please check the following:
  1. Use Dynamixel Wizard to confirm that all Dynamixels are properly detected.
  2. Verify that the IDs are set to 11-15.
  3. Ensure that the baud rate is set to 1,000,000 for all Dynamixels.
  4. If a firmware update is available, please proceed with the update.
If the problem continues after completing these steps, please copy the entire error message or provide a screenshot.
Hi YunWonho, thank you for your reply. I hate to say this, but I’ve already tried all of those, and it still seems to give me the same error. Do you have any other options for me?
[SYNC_READ_FAIL] Please share the log where the error occurs. If you look at the log above, it seems to be working normally.
