#include "ros/ros.h"
#include <geometry_msgs/Point.h>
#include <std_msgs/String.h>
#include <iostream>
#include "../include/op_follow/main_window.hpp"
#include "../include/op_follow/qnode.hpp"
#include <ros/network.h>
#include "body_tracker_msgs/BodyTracker.h" // Publish custom message
#include "body_tracker_msgs/Skeleton.h"
#include <visualization_msgs/Marker.h>
std::vector<double> present_kinematic_position_;
open_manipulator_msgs::KinematicsPose kinematics_pose_msg;
double path_time = 2;
float a,b,c;
int initcount = 1;
float init_xpose, init_ypose, init_zpose;
class ttm
private:
ros::NodeHandle n_;
ros::ServiceClient move_client_;
ros::Subscriber sub_;
ros::Subscriber present_pose_sub;
ros::Subscriber hand_xyz_data_sub;
ros::ServiceClient gripper_client;
ros::ServiceClient joint_client_;
public:
ttm()
gripper_client = n_.serviceClient<open_manipulator_msgs::SetJointPosition>("goal_tool_control");
move_client_ = n_.serviceClient<open_manipulator_msgs::SetKinematicsPose>("goal_task_space_path_position_only");
present_pose_sub = n_.subscribe("open_manipualtor/gripper/kinematics_pose", 10, &ttm::kinematicsPoseCallback, this);
joint_client_ = n_.serviceClient<open_manipulator_msgs::SetJointPosition>("goal_joint_space_path");
hand_xyz_data_sub = n_.subscribe("body_tracker/skeleton", 10, &ttm::xyzpointCallback, this);
bool setJointSpacePath(std::vector<std::string> joint_name, std::vector<double> joint_angle, double path_time)
open_manipulator_msgs::SetJointPosition srv;
srv.request.joint_position.joint_name = joint_name;
srv.request.joint_position.position = joint_angle;
srv.request.path_time = path_time;
ROS_INFO("-- x( %.3lf) y( %.3lf) z( %.3lf)\n", srv.request.joint_position.position[0], srv.request.joint_position.position[1], srv.request.joint_position.position[2]);
if(joint_client_.call(srv))
return srv.response.is_planned;
return false;
void init()
std::vector<std::string> joint_name_;
std::vector<double> joint_angle;
joint_name_.push_back("joint1");
joint_name_.push_back("joint2");
joint_name_.push_back("joint3");
joint_name_.push_back("joint4");
joint_angle.push_back( 0.00);
joint_angle.push_back(-1.05);
joint_angle.push_back( 0.35);
joint_angle.push_back( 0.70);
setJointSpacePath(joint_name_, joint_angle, path_time);
ROS_INFO("INIT MODE SET");
void kinematicsPoseCallback(const open_manipulator_msgs::KinematicsPose::ConstPtr &msg)
std::vector<double> temp_position;
temp_position.push_back(msg->pose.position.x);
temp_position.push_back(msg->pose.position.y);
temp_position.push_back(msg->pose.position.z);
present_kinematic_position_ = temp_position;
kinematics_pose_msg.pose = msg->pose;
void xyzpointCallback(const body_tracker_msgs::Skeleton::ConstPtr &handdata)
std::vector<double> kinematics_pose;
int gripper = handdata->gesture;
if(initcount == 1)
init_xpose = handdata->joint_position_right_hand.x;
init_ypose = handdata->joint_position_right_hand.y;
init_zpose = handdata->joint_position_right_hand.z;
initcount++;
return;
else
float present_xpose = handdata->joint_position_right_hand.x;
float present_ypose = handdata->joint_position_right_hand.y;
float present_zpose = handdata->joint_position_right_hand.z;
float movex = present_xpose - init_xpose;
float movey = present_ypose - init_ypose;
float movez = present_zpose - init_zpose;
kinematics_pose.push_back(movex);
kinematics_pose.push_back(movey);
kinematics_pose.push_back(movez);
setTaskSpacePath(kinematics_pose, path_time);
ROS_INFO("-- x( %.3lf) y( %.3lf) z( %.3lf)\n", movex, movey, movez);
if(gripper >= 1)
gripper_close();
else
gripper_open();
return;
bool setTaskSpacePath(std::vector<double> kinematics_pose, double path_time)
open_manipulator_msgs::SetKinematicsPose srv;
srv.request.end_effector_name = "gripper";
if( std::isnan(kinematics_pose.at(0)) || std::isnan(kinematics_pose.at(1)) || std::isnan(kinematics_pose.at(2)) )
std::cerr << "Warning Error: NaN value operation.";
return false;
srv.request.kinematics_pose.pose.position.x = kinematics_pose.at(0);
srv.request.kinematics_pose.pose.position.y = kinematics_pose.at(1);
srv.request.kinematics_pose.pose.position.z = kinematics_pose.at(2);
srv.request.kinematics_pose.pose.orientation.w = kinematics_pose_msg.pose.orientation.w;
srv.request.kinematics_pose.pose.orientation.x = kinematics_pose_msg.pose.orientation.x;
srv.request.kinematics_pose.pose.orientation.y = kinematics_pose_msg.pose.orientation.y;
srv.request.kinematics_pose.pose.orientation.z = kinematics_pose_msg.pose.orientation.z;
// ROS_INFO("-- x( %.3lf, %.3lf) y( %.3lf, %.3lf) z( %.3lf, %.3lf) w( %.3lf)\n", kinematics_pose.at(0), srv.request.kinematics_pose.pose.orientation.x,
// kinematics_pose.at(1), srv.request.kinematics_pose.pose.orientation.y, kinematics_pose.at(2), srv.request.kinematics_pose.pose.orientation.z, srv.request.kinematics_pose.pose.orientation.w );
if(move_client_.call(srv))
ROS_INFO("move robot arm");
return false;
void gripper_open(void)
joint_angle.push_back(0.01);
if(setToolControl(joint_angle))
ROS_INFO("Send gripper open");
return;
ROS_INFO("[ERROR] gripper open service");
void gripper_close(void)
joint_angle.push_back(-0.01);
ROS_INFO("Send gripper close");
return;
ROS_INFO("[ERROR] gripper close service");
bool setToolControl(std::vector<double> joint_angle)
srv.request.joint_position.joint_name.push_back("gripper");
if(gripper_client.call(srv))
return false;
int main(int argc, char **argv)
ros::init(argc, argv, "follow");
ros::start();
ros::Rate loop_rate(10);
ttm ttm1;
ttm1.init();
// ttm1.gripper_open();
ros::spin();
return 0;
위의 코드가 제가 작성한 코드입니다. 저는 ros kinetic과 openmanipulator x를 사용하였습니다. 저는 emanual에 있는 패키지들을 참고하여 위의 코드를 작성하였습니다.
