This project is control the manipulator with MoveIt!
I tried apply to MoveIt pkg to the manipulator. This attempt was half the success.
I succeeded in controlling the manipulator, but moving is not smooth. ![]()
Could you show me steps to control a real robot with moveit? what is the workflow for this? I have been struggling to control it for along time. Thank you!
Sir you have Arduino based Robotic Arm /Industrial Arm ? if you have Arduino based Robotic arm with Hobbyist servo motors and want to control with Moveit then i will help you . if you have Industrial Arms and want to control with Moveit . I will prefer you to look at ROS industrial website .
my robot is controlled by a Raspberry-Pi. I have used Ros to control server MG966 already, now when I interact the arm in MoveIt, specifically, I run moveit_plainning_execution.launch and nothing happen. I know that I have to publish a goal to ActionServer, but this step is still unclear.
Could you explain the workflow what I need to do? Could you share your source code???
Sir i did this project with Arduino and for that i write a Arduino node which Subscribe the Move_group which publish the angles and then send that Angeles to the Arduino which helps you to rotate the servo motor based on desired Angles .
What kind of servo do you use? Is that Dynamixel series? I am using MG966???
sir can you share your project details
i Also used MG995 and MG996R motors with Additional Potentiometer, Which are alredy inbuilt in Motors.
I can Share details just ask me what you need to ask .
