I want to measure the torque of each Dynamixel in operation. To do so, I realized that I need to measure the current, and currently, I am trying to measure the current for each Dynamixel.
Therefore, I installed the Dynamixel SDK on Ubuntu 22.04, modified an example, and created a code to measure the current using Python in VScode. However, the measured current values were extremely large, and I couldn’t figure out what these values meant despite considering various possibilities. Below, I have posted the code I wrote and the resulting measurements. These results are the current values measured during the movement from the second goal position to the third goal position.
If anyone knows what the numbers for “present current” mean or how to convert them, I would appreciate your help.
Unfortunately, due to a 32,000 character limit, the code will be posted in the next message.
link:
-----------------------------------------------------Result----------------------------------------------------
[ID:011] PresentCurrent:000 [ID:012] PresentCurrent:65532 [ID:013] PresentCurrent:65498 [ID:014] PresentCurrent:65508
[ID:011] PresentCurrent:000 [ID:012] PresentCurrent:65530 [ID:013] PresentCurrent:65492 [ID:014] PresentCurrent:65507
[ID:011] PresentCurrent:000 [ID:012] PresentCurrent:65532 [ID:013] PresentCurrent:65494 [ID:014] PresentCurrent:65506
[ID:011] PresentCurrent:000 [ID:012] PresentCurrent:65534 [ID:013] PresentCurrent:65489 [ID:014] PresentCurrent:65509
[ID:011] PresentCurrent:008 [ID:012] PresentCurrent:65534 [ID:013] PresentCurrent:65478 [ID:014] PresentCurrent:65530
[ID:011] PresentCurrent:002 [ID:012] PresentCurrent:001 [ID:013] PresentCurrent:65465 [ID:014] PresentCurrent:65526
[ID:011] PresentCurrent:006 [ID:012] PresentCurrent:000 [ID:013] PresentCurrent:65456 [ID:014] PresentCurrent:65529
[ID:011] PresentCurrent:011 [ID:012] PresentCurrent:000 [ID:013] PresentCurrent:65434 [ID:014] PresentCurrent:65533
[ID:011] PresentCurrent:65540 [ID:012] PresentCurrent:65537 [ID:013] PresentCurrent:65431 [ID:014] PresentCurrent:131070
[ID:011] PresentCurrent:131076 [ID:012] PresentCurrent:196608 [ID:013] PresentCurrent:65423 [ID:014] PresentCurrent:196605
[ID:011] PresentCurrent:262149 [ID:012] PresentCurrent:262146 [ID:013] PresentCurrent:4294967171 [ID:014] PresentCurrent:327676
[ID:011] PresentCurrent:393223 [ID:012] PresentCurrent:393216 [ID:013] PresentCurrent:4294967166 [ID:014] PresentCurrent:393210
[ID:011] PresentCurrent:524294 [ID:012] PresentCurrent:524288 [ID:013] PresentCurrent:4294901626 [ID:014] PresentCurrent:524284
[ID:011] PresentCurrent:655367 [ID:012] PresentCurrent:655360 [ID:013] PresentCurrent:4294836098 [ID:014] PresentCurrent:655355
[ID:011] PresentCurrent:786437 [ID:012] PresentCurrent:786432 [ID:013] PresentCurrent:4294705031 [ID:014] PresentCurrent:786429
[ID:011] PresentCurrent:851976 [ID:012] PresentCurrent:917504 [ID:013] PresentCurrent:4294508430 [ID:014] PresentCurrent:917496
[ID:011] PresentCurrent:983046 [ID:012] PresentCurrent:1048576 [ID:013] PresentCurrent:4294311821 [ID:014] PresentCurrent:1048573
[ID:011] PresentCurrent:1114119 [ID:012] PresentCurrent:1114112 [ID:013] PresentCurrent:4294115215 [ID:014] PresentCurrent:1179641
[ID:011] PresentCurrent:1245190 [ID:012] PresentCurrent:1245184 [ID:013] PresentCurrent:4293918611 [ID:014] PresentCurrent:1310713
[ID:011] PresentCurrent:1376262 [ID:012] PresentCurrent:1441791 [ID:013] PresentCurrent:4293722001 [ID:014] PresentCurrent:1441788
[ID:011] PresentCurrent:1507335 [ID:012] PresentCurrent:1507328 [ID:013] PresentCurrent:4293590932 [ID:014] PresentCurrent:1572862
[ID:011] PresentCurrent:1638404 [ID:012] PresentCurrent:1703934 [ID:013] PresentCurrent:4293394321 [ID:014] PresentCurrent:1638396
[ID:011] PresentCurrent:1769478 [ID:012] PresentCurrent:1703936 [ID:013] PresentCurrent:4293263248 [ID:014] PresentCurrent:1769467
[ID:011] PresentCurrent:1900551 [ID:012] PresentCurrent:1835008 [ID:013] PresentCurrent:4293132176 [ID:014] PresentCurrent:1900539
[ID:011] PresentCurrent:1966088 [ID:012] PresentCurrent:2031615 [ID:013] PresentCurrent:4293066640 [ID:014] PresentCurrent:2031610
[ID:011] PresentCurrent:2097160 [ID:012] PresentCurrent:2162687 [ID:013] PresentCurrent:4292935567 [ID:014] PresentCurrent:2162683
[ID:011] PresentCurrent:2228234 [ID:012] PresentCurrent:2293759 [ID:013] PresentCurrent:4292804495 [ID:014] PresentCurrent:2293756
[ID:011] PresentCurrent:2293770 [ID:012] PresentCurrent:2424828 [ID:013] PresentCurrent:4292673420 [ID:014] PresentCurrent:2424827
[ID:011] PresentCurrent:2424842 [ID:012] PresentCurrent:2555903 [ID:013] PresentCurrent:4292607885 [ID:014] PresentCurrent:2555900
[ID:011] PresentCurrent:2555913 [ID:012] PresentCurrent:2686973 [ID:013] PresentCurrent:4292476825 [ID:014] PresentCurrent:2686970
[ID:011] PresentCurrent:2686989 [ID:012] PresentCurrent:2752512 [ID:013] PresentCurrent:4292345747 [ID:014] PresentCurrent:2752509
[ID:011] PresentCurrent:2818059 [ID:012] PresentCurrent:2949116 [ID:013] PresentCurrent:4292214668 [ID:014] PresentCurrent:2883582
[ID:011] PresentCurrent:2949129 [ID:012] PresentCurrent:3014651 [ID:013] PresentCurrent:4292083602 [ID:014] PresentCurrent:3014649
[ID:011] PresentCurrent:3080203 [ID:012] PresentCurrent:3145724 [ID:013] PresentCurrent:4291952527 [ID:014] PresentCurrent:3145720
[ID:011] PresentCurrent:3211276 [ID:012] PresentCurrent:3276796 [ID:013] PresentCurrent:4291821461 [ID:014] PresentCurrent:3276797
[ID:011] PresentCurrent:3342342 [ID:012] PresentCurrent:3407866 [ID:013] PresentCurrent:4291690388 [ID:014] PresentCurrent:3407871
[ID:011] PresentCurrent:3473411 [ID:012] PresentCurrent:3538939 [ID:013] PresentCurrent:4291559314 [ID:014] PresentCurrent:3538939
[ID:011] PresentCurrent:3538945 [ID:012] PresentCurrent:3670010 [ID:013] PresentCurrent:4291428242 [ID:014] PresentCurrent:3604477
[ID:011] PresentCurrent:3604481 [ID:012] PresentCurrent:3801078 [ID:013] PresentCurrent:4291297174 [ID:014] PresentCurrent:3735548
[ID:011] PresentCurrent:3735553 [ID:012] PresentCurrent:3932147 [ID:013] PresentCurrent:4291166102 [ID:014] PresentCurrent:3866616
[ID:011] PresentCurrent:3735552 [ID:012] PresentCurrent:4063219 [ID:013] PresentCurrent:4291100560 [ID:014] PresentCurrent:3932160
[ID:011] PresentCurrent:3735552 [ID:012] PresentCurrent:4194292 [ID:013] PresentCurrent:4290969486 [ID:014] PresentCurrent:4063232
[ID:011] PresentCurrent:3735552 [ID:012] PresentCurrent:4325361 [ID:013] PresentCurrent:4290838419 [ID:014] PresentCurrent:4259839
[ID:011] PresentCurrent:3670016 [ID:012] PresentCurrent:4456435 [ID:013] PresentCurrent:4290707353 [ID:014] PresentCurrent:4390907
[ID:011] PresentCurrent:3604480 [ID:012] PresentCurrent:4587508 [ID:013] PresentCurrent:4290576279 [ID:014] PresentCurrent:4456436
[ID:011] PresentCurrent:3538944 [ID:012] PresentCurrent:4718581 [ID:013] PresentCurrent:4290445208 [ID:014] PresentCurrent:4587518
[ID:011] PresentCurrent:3538943 [ID:012] PresentCurrent:4784111 [ID:013] PresentCurrent:4290314133 [ID:014] PresentCurrent:4653050
[ID:011] PresentCurrent:3342336 [ID:012] PresentCurrent:4915185 [ID:013] PresentCurrent:4290248594 [ID:014] PresentCurrent:4653050
[ID:011] PresentCurrent:3211264 [ID:012] PresentCurrent:5046253 [ID:013] PresentCurrent:4290117522 [ID:014] PresentCurrent:4653050
[ID:011] PresentCurrent:3080192 [ID:012] PresentCurrent:5177325 [ID:013] PresentCurrent:4289986456 [ID:014] PresentCurrent:4653049
[ID:011] PresentCurrent:2949120 [ID:012] PresentCurrent:5308395 [ID:013] PresentCurrent:4289855388 [ID:014] PresentCurrent:4587513
[ID:011] PresentCurrent:2883584 [ID:012] PresentCurrent:5439465 [ID:013] PresentCurrent:4289724312 [ID:014] PresentCurrent:4521977
[ID:011] PresentCurrent:2752512 [ID:012] PresentCurrent:5570540 [ID:013] PresentCurrent:4289593233 [ID:014] PresentCurrent:4456434
[ID:011] PresentCurrent:2621440 [ID:012] PresentCurrent:5701605 [ID:013] PresentCurrent:4289462159 [ID:014] PresentCurrent:4390903
[ID:011] PresentCurrent:2555903 [ID:012] PresentCurrent:5832674 [ID:013] PresentCurrent:4289331097 [ID:014] PresentCurrent:4259833
[ID:011] PresentCurrent:2359296 [ID:012] PresentCurrent:5963748 [ID:013] PresentCurrent:4289200035 [ID:014] PresentCurrent:4194300
[ID:011] PresentCurrent:2293759 [ID:012] PresentCurrent:6094819 [ID:013] PresentCurrent:4289068960 [ID:014] PresentCurrent:4063226
[ID:011] PresentCurrent:2097152 [ID:012] PresentCurrent:6160351 [ID:013] PresentCurrent:4288937880 [ID:014] PresentCurrent:3932153
[ID:011] PresentCurrent:2031616 [ID:012] PresentCurrent:6291419 [ID:013] PresentCurrent:4288872346 [ID:014] PresentCurrent:3801073
[ID:011] PresentCurrent:1900544 [ID:012] PresentCurrent:6422489 [ID:013] PresentCurrent:4288741283 [ID:014] PresentCurrent:3735548
[ID:011] PresentCurrent:1835006 [ID:012] PresentCurrent:6488028 [ID:013] PresentCurrent:4288675753 [ID:014] PresentCurrent:3604473
[ID:011] PresentCurrent:1638400 [ID:012] PresentCurrent:6488022 [ID:013] PresentCurrent:4288610210 [ID:014] PresentCurrent:3473405
[ID:011] PresentCurrent:1507328 [ID:012] PresentCurrent:6553556 [ID:013] PresentCurrent:4288610204 [ID:014] PresentCurrent:3342328
[ID:015] PresentCurrent:65534
[ID:015] PresentCurrent:65535
[ID:015] PresentCurrent:000
[ID:015] PresentCurrent:006
[ID:015] PresentCurrent:004
[ID:015] PresentCurrent:008
[ID:015] PresentCurrent:65544
[ID:015] PresentCurrent:65543
[ID:015] PresentCurrent:131083
[ID:015] PresentCurrent:196622
[ID:015] PresentCurrent:327695
[ID:015] PresentCurrent:393233
[ID:015] PresentCurrent:524302
[ID:015] PresentCurrent:720912
[ID:015] PresentCurrent:851980
[ID:015] PresentCurrent:983054
[ID:015] PresentCurrent:1179662
[ID:015] PresentCurrent:1310731
[ID:015] PresentCurrent:1441802
[ID:015] PresentCurrent:1572877
[ID:015] PresentCurrent:1703947
[ID:015] PresentCurrent:1835021
[ID:015] PresentCurrent:1900559
[ID:015] PresentCurrent:2031629
[ID:015] PresentCurrent:2162699
[ID:015] PresentCurrent:2293772
[ID:015] PresentCurrent:2359311
[ID:015] PresentCurrent:2490377
[ID:015] PresentCurrent:2621454
[ID:015] PresentCurrent:2752523
[ID:015] PresentCurrent:2883591
[ID:015] PresentCurrent:3014671
[ID:015] PresentCurrent:3145739
[ID:015] PresentCurrent:3276811
[ID:015] PresentCurrent:3342345
[ID:015] PresentCurrent:3473418
[ID:015] PresentCurrent:3604489
[ID:015] PresentCurrent:3735566
[ID:015] PresentCurrent:3866635
[ID:015] PresentCurrent:3997707
[ID:015] PresentCurrent:4128780
[ID:015] PresentCurrent:4259852
[ID:015] PresentCurrent:4325391
[ID:015] PresentCurrent:4456458
[ID:015] PresentCurrent:4587533
[ID:015] PresentCurrent:4718604
[ID:015] PresentCurrent:4849680
[ID:015] PresentCurrent:4980751
[ID:015] PresentCurrent:5111820
[ID:015] PresentCurrent:5177357
[ID:015] PresentCurrent:5308429
[ID:015] PresentCurrent:5439501
[ID:015] PresentCurrent:5570574
[ID:015] PresentCurrent:5701645
[ID:015] PresentCurrent:5832714
[ID:015] PresentCurrent:5963786
[ID:015] PresentCurrent:6029325
[ID:015] PresentCurrent:6160396
[ID:015] PresentCurrent:6225932
[ID:015] PresentCurrent:6291465
[ID:015] PresentCurrent:6357001
[ID:015] PresentCurrent:6422539
[ID:015] PresentCurrent:6422540
[ID:015] PresentCurrent:6422536
[ID:015] PresentCurrent:6488072
[ID:015] PresentCurrent:6488073
[ID:015] PresentCurrent:6488074
[ID:015] PresentCurrent:6488075
[ID:015] PresentCurrent:6488071
[ID:015] PresentCurrent:6488076
[ID:015] PresentCurrent:6488070
[ID:015] PresentCurrent:6488068
[ID:015] PresentCurrent:6488069
[ID:015] PresentCurrent:6422535
[ID:015] PresentCurrent:6356998
[ID:015] PresentCurrent:6291462
[ID:015] PresentCurrent:6225927
[ID:015] PresentCurrent:6094854
[ID:015] PresentCurrent:6029317
[ID:015] PresentCurrent:5898242
[ID:015] PresentCurrent:5832710
[ID:015] PresentCurrent:5701635
[ID:015] PresentCurrent:5570561
[ID:015] PresentCurrent:5439492
[ID:015] PresentCurrent:5373953
[ID:015] PresentCurrent:5242883
[ID:015] PresentCurrent:5111811
[ID:015] PresentCurrent:4980736
[ID:015] PresentCurrent:4849667
[ID:015] PresentCurrent:4718597
[ID:015] PresentCurrent:4653062
[ID:015] PresentCurrent:4521988
[ID:015] PresentCurrent:4390914
[ID:015] PresentCurrent:4259843
[ID:015] PresentCurrent:4128771
[ID:015] PresentCurrent:3997696
[ID:015] PresentCurrent:3866628
[ID:015] PresentCurrent:3801093
[ID:015] PresentCurrent:3670016
[ID:015] PresentCurrent:3538947
[ID:015] PresentCurrent:3407872
[ID:015] PresentCurrent:3276802
[ID:015] PresentCurrent:3145728
[ID:015] PresentCurrent:3014657
[ID:015] PresentCurrent:2883587
[ID:015] PresentCurrent:2752515
[ID:015] PresentCurrent:2686977
[ID:015] PresentCurrent:2555904
[ID:015] PresentCurrent:2424832
[ID:015] PresentCurrent:2293761
[ID:015] PresentCurrent:2162689
[ID:015] PresentCurrent:2031618
[ID:015] PresentCurrent:1900545
[ID:015] PresentCurrent:1769472
[ID:015] PresentCurrent:1638400
[ID:015] PresentCurrent:1507328
[ID:015] PresentCurrent:1376257
XM430-W350-T 5EA (Openmanipulator X set)
DYNAMIXEL Controller: OpenCR 1.0
Software Interface: Python in VScode, Dynamixel_SDK, Ubuntu 22.04
